[gdal-dev] encoding in custom python functions
Lauri Kajan lauri.kajan at gmail.com
Thu Oct 22 00:36:09 PDT 2015
Hi all,
I'm trying to figure out some encoding problems when using custom python
expression functions.
I'm using python functions for defining some label texts. I need use some
special characters like ä and ö.
When a new file is created in function editor the file is encoded in my
system encoding cp1252. At least the ä is coded to 0xe4 if I check that
with hex-editor.
Let the custom function just be
@qgsfunction(args='auto', group='Custom')
def encodingtest(feature, parent):
return 'ä'
This displays on a map like 'ä'
It seems that the file is converted to utf-8 before execution and the ä is
then coded to 0xc3 0xa4. Now QGIS still tries to interpret this as cp1252
and then displays this as 'ä'.
It doesn't help to define the ä as unicode like u'ä' because QGIS still
sees the ä as 0xc3 0xa4 and think that it is in cp1252.
The only way to resolve this in the code at least that I have found is to
use
return 'ä'.decode('utf-8')
This works on QGIS but the file can't be executed elsewhere (IDE) since the
file is truly in cp1252 and 0xe4 can't be decoded using utf-8.
Does anyone else confirm this and have I understood right the problem?
Should I file a bug report?
Thanks,
-Lauri
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151022/340006c3/attachment.html>
