[gdal-dev] Build OGR with ESRI SDE
MrMartin pascoal.egeo at gmail.com
Thu Oct 22 01:51:49 PDT 2015
i have this same issue but  "in order to deploy ArcSDE technology as an
enterprise geodatabase you must have, or be prepared to purchase, an ArcGIS
Server license"
<http://gis.stackexchange.com/questions/124256/where-to-download-arcsde>  ,
is this a must?
Since that geotools has  " ArcSDE plugin allows the GeoTools developer to
work with the ArcSDE middle ware"
<http://gis.stackexchange.com/questions/124256/where-to-download-arcsde>   i
wounder if it is possible to use this plugin to build a OGR SDE Driver?
Any suggestion or opinion about this issue would be great.
Thanks in advance.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Build-OGR-with-ESRI-SDE-tp3757320p5231900.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
