[gdal-dev] Problem with using ogr2ogr to migrate data from Postgis to TSQL/Oracle Spatial
surma bojan.surma at gmail.com
Sun Oct 25 10:04:14 PDT 2015
Oh, cheers man, this does the trick. Totally forgot that I could cast the
column.
Thank you.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-using-ogr2ogr-to-migrate-data-from-Postgis-to-TSQL-Oracle-Spatial-tp5232425p5232463.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
