[gdal-dev] hdf5 dataset. Header data too long. Truncated
Even Rouault even.rouault at spatialys.com
Tue Sep 1 08:08:39 PDT 2015
Le mardi 01 septembre 2015 16:50:32, Rashad M a écrit :
> Hello all,
> I have an the following warning from gdal when reading .h5 dataset
> Warning 2: Header data too long. Truncated.
> Looking at frmts/hdf5/hdf5dataset.cpp there is a define for
> MAX_METADATA_LEN
> #define MAX_METADATA_LEN 32768
> and there is a check
>                 if( CPLStrlcat(szValue, szData, MAX_METADATA_LEN) >=
> MAX_METADATA_LEN )
>                     CPLError( CE_Warning, CPLE_OutOfMemory,
>                               "Header data too long. Truncated\n");
This was introduced in https://trac.osgeo.org/gdal/changeset/20438 to avoid
crashes. Potentially it could be reworked to deal with arbitrary long
metadata. Although it could be kind of annoying to have too long values as
metadata item, especially in the main metadata domain. A cleaner solution
would perhaps be have something like "MY_ITEM=<value removed because too
large. query HDF5 metadata domain to get it>" and you'd have the full value in
the HDF5 metadata domain (perhaps not unlimited but with a much higher limit,
let's say 1 MB per item). People with more experience with HDF5 datasets could
perhaps comment.
> Now I could update MAX_METADATA_LEN but is there a way it can set be set at
> runtime ?
No, you need to recompile.
http://www.spatialys.com
