[gdal-dev] The histogram results from a vrt datsource when the rasters are partially overlapped
Even Rouault even.rouault at spatialys.com
Thu Sep 3 01:27:21 PDT 2015
Le jeudi 03 septembre 2015 09:03:29, Andrea Peri a écrit :
> Hi,
> I have a VRT datasource, with more raster inside.
> Each raster is partially overlapped to the two near rasters.
> My dubt is how the histogram retrieved using the API GetDefaultHistogram,
> is counting the overlapping.
> Infact the overlapping portin is more NULL values, but also there is
> portion f informations.
> Is in a pixel overlapped there is a NULL from frame1 and a VALUE from
> frame2. I could guess the Histogram ignore the NULL from frame1 and count
> only the VALUE from frame2.
> But when the frame1 and frame2 give the differents values: VALUE1 and
> VALUE2. In this case what is the value counted in the histogram ?
> It count the top level raster only, the first raster only, use a mean
> of both or count both duplicating so the number of cell in the results
Andrea,
Hopefully (and that's what the existing code is supposed to do), the histogram
reported on the VRT should be the same as the one you would get on a GeoTIFF
that would result from the conversion of the VRT. Said other wise, it should
be the histogram of what is displayed.
Even
http://www.spatialys.com
