[gdal-dev] error parsing metadata from HDF5 dataset
Rashad M mohammedrashadkm at gmail.com
Thu Sep 3 12:10:54 PDT 2015
On Thu, Sep 3, 2015 at 5:41 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> > Sure. The patch is for 1.11 branch. Should I generate the same for trunk
> > also?
> Yes please
> > As we are on the subject of metadata in hdf5 dataset,  there is  Header
> too
> > long. .. Truncated warning appearing when type is double which now has
> > format specifier as %.16g
> > using simply %g or %lg fixed the issue on my side. If okay, I will
> include
> > that too in the patch.
> Please do not include that in your patch. That's a different issue. I'm not
> sure %g or %lg is fine for all intended uses. Some use cases might
> potentially
> need very precise values.
okay. I will remove that from this patch. and will ask further queries in
the other thread. :)
> > Thanks.
> > > > OS: Fedora 20 x86_64
> > > > gdal branch: 1.11
> > > > svn info
> > > > Path: .
> > > > Working Copy Root Path: /home/mkanavat/sources/gdal_branch_1.11
> > > > URL: http://svn.osgeo.org/gdal/branches/1.11/gdal
> > > > Relative URL: ^/branches/1.11/gdal
> > > > Repository Root: http://svn.osgeo.org/gdal
> > > > Repository UUID: f0d54148-0727-0410-94bb-9a71ac55c965
> > > > Revision: 30007
> > > > Node Kind: directory
> > > > Schedule: normal
> > > > Last Changed Author: rouault
> > > > Last Changed Rev: 30005
> > > > Last Changed Date: 2015-09-01 10:17:50 +0200 (Tue, 01 Sep 2015)
> > > Spatialys - Geospatial professional services
> > > http://www.spatialys.com
> > > _______________________________________________
> > > gdal-dev mailing list
> > > gdal-dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150903/cf644f30/attachment.html>
