[gdal-dev] Mosaicking question...
Even Rouault even.rouault at spatialys.com
Sat Sep 5 16:53:39 PDT 2015
Le dimanche 06 septembre 2015 01:43:49, Jonathan Greenberg a écrit :
> GDALers:
> Quick question: if I'm using the gdalbuildvrt -> gdal_translate trick to
> mosaic images, where I have "holes" (missing tiles), how do I set the value
> of the regions where there is no image?  Is this done in gdalbuildvrt or
> gdal_translate?
Jonathan,
You should be able to do it with the -vrtnodata (potentially with -hidenodata)
switches of gdalbuildvrt
Even
http://www.spatialys.com
