[gdal-dev] projection error
Even Rouault even.rouault at spatialys.com
Tue Sep 8 05:56:18 PDT 2015
Le mardi 08 septembre 2015 14:43:51, y hema a écrit :
> hi ,
> poDataset = (GDALDataset *) GDALOpen( pszFilename, GA_ReadOnly );
>     if( poDataset != NULL )
>         numBands = poDataset->GetRasterCount();
>         width = poDataset->GetRasterXSize();
>         height = poDataset->GetRasterYSize();
>         GDALRasterBand  *poBand;
>         poBands = new GDALRasterBand*[numBands];
>         poBand = poDataset->GetRasterBand(1);
>         dataType = (GDALDataType)poBand->GetRasterDataType();
>         bytesPerPixel =GDALGetDataTypeSize((GDALDataType)dataType)/8;
>     const char *ch =   poDataset->GetProjectionRef();
>     double *tiepoints = new double[6];
>     poDataset->GetGeoTransform(tiepoints);
>     for(int i=0;i<6;i++)
>         qDebug()<<"tie points"<< tiepoints[0];
>     uchar *data;
>     data = (uchar *) /*CPLMalloc*/new
> char[(sizeof(uchar)*width*height*bytesPerPixel*numBands)];
>     int bandIndices[numBands];
>     double scale = 5.0;
>     for(int j=0 ;j<numBands ;j++)
>         bandIndices[j] = j;
>     for(int i = 0; i < numBands; i++)
>         poBands[i] = poDataset->GetRasterBand(bandIndices[i]+1);
>         poBands[i]->SetScale(10);
>         poBands[i]->RasterIO(GF_Read, 0, 0, width,
> height,data+(bytesPerPixel*i), width, height, (GDALDataType)dataType,
> numBands*bytesPerPixel, 0);
> actually i am trying to read the projection string and the tie points .the
> above is the code im using.
I don't see how the above code would cause the "Only OGC WKT Projections
supported for writing to GeoTIFF" error to be emitted. This error can only be
raised if you call SetProjection(). Here you call GetProjectionRef() (which is
fine if your intent is to read the projection string).
In the above code, I can just tell that SetScale() call will be without effect:
you likely want the RasterIO() to return values multiplied by 10, but
SetScale() just set a sort of metadata that has no effect on the returned
values and only makes sense when you create/modify a raster.
Even
http://www.spatialys.com
