[gdal-dev] GDAL testing
Dmitry Baryshnikov bishop.dev at gmail.com
Tue Sep 15 07:46:19 PDT 2015
Hi Karl,
I think that some ready tests of GDAL are available. I'm not familiar
with autotest2, so some links to docs and sources are welcome. Also I
think that in gist you provided only some examples, and somewhere else
the repo exists. If not - I'll try to play with this code.
Best regards,
     Dmitry
15.09.2015 00:42, Kurt Schwehr пишет:
> Hi Dmitry,
> I didn't totally understand your question.  I don't have autotest2
> really out yet.  You are welcome to use the sample test files that I
> posted in any way that the Apache 2.0 license allows.
> -kurt
> On Sun, Sep 6, 2015 at 8:27 AM, Dmitry Baryshnikov
> <bishop.dev at gmail.com <mailto:bishop.dev at gmail.com>> wrote:
>     Hi Kurt,
>     During code sprint in Korea (FOSS4G 2015) I plan to play with new
>     approach of CMake fro GDAL. The one of experiments will be try to
>     use CTest. As I plan restructure the sources tree, I can try to
>     integrate you work on autotest2 and CTest. Also we can try to
>     create new test directory structure more compatible for test and
>     sources tree (this is about you wrote: Probably should move python
>     code to also match the C++ tree.  e.g. tiff_read_test.py ->
>     autotest2/py/frmts/gtiff/tiff_read_test.py).
>     How can get you tests? What do I need to use autotest2?
>     Best regards,
>          Dmitry
>     05.09.2015 20:37, Kurt Schwehr пишет:
>>     (Subject change to focus on testing)
>>     Hi all,
>>     First off... what GDAL has with autotest, travis-ci and coverity
>>     is awesome!
>>     Thoughts / discussion more than welcome!
>>     For my production work, I'm not able to use the autotest python
>>     code because of its non-unittest architecture.  So... I started
>>     creating python unittest and C++ gunit based tests.  I use
>>     autotest2 in Google's internal continuous integration system in
>>     our main code base.  I'm using Google's build system... I've got
>>     nothing started for running the C++ tests outside of Google.
>>     Apologies for not even getting out at least samples of autotest2
>>     for folks to inspect and comment on.  My intention is to put what
>>     I have in a git repo and the to start discussions as to what (if
>>     anything) GDAL community wants to do with autotest2.    I was
>>     hoping to get a lot more coverage and get GDAL 2.x.x support, but
>>     that will have to come later.  It's only 14K lines at this point
>>     (optimistically 2-3% done), but it has been a huge help for me
>>     especially with in upgrading versions of gdal and catching bugs
>>     in support libs & development toolchains.
>>     The tests are more focused on test isolation than autotest.  This
>>     allows for a lot more parallelism in testing.  e.g.  It's fair
>>     game to run all tests at the same time on the same machine.
>>     find . -name \*.py | xargs wc -l | tail -1
>>      10684 total
>>     find . -name \*.cc -o -name \*.h | xargs wc -l | tail -1
>>       3734 total
>>     Where GDAL's autotest is 204K lines:
>>       193994 total
>>     find . -name \*.c\* -o -name \*.h | xargs wc -l | tail -1
>>        10471 total
>>     Here are some samples:
>>     C++ tests use  C++11, gunit, google logging, gflags:  (Hoping for
>>     C++14 soon.. e.g. make_unique)
>>     - autotest2/cpp/port/cpl_conv_test.cc
>>     <https://gist.github.com/schwehr/13137d826763763fb031> (Yes, this
>>     is massively boring code)
>>     - autotest2/cpp/ogr/ogrpoint_test.cc
>>     <https://gist.github.com/schwehr/c8ee86a6f6a1c1cc043b>
>>     - autotest2/cpp/ogr/ogrsf_frmts/geojson/geojson_test.cc
>>     <https://gist.github.com/schwehr/bc44b91a37cd621212c4>
>>     Python pretty much follows the autotest layout, but with util
>>     files in the same directory.  Assumes python 2.7 or >= 3.4 (have
>>     not tried py3 yet)
>>     - autotest2/gcore/gcore_util.py
>>     <https://gist.github.com/schwehr/c143927ca25d03a10265>
>>     - autotest2/gdrivers/gdrivers_util.py
>>     <https://gist.github.com/schwehr/dd75f73cedf8f7b5357e>
>>     - autotest2/gdrivers/tiff_read_test.py
>>     <https://gist.github.com/schwehr/a35b2bc8a7956ef1f620> (I'm
>>     leading towards moving driver tests in gcore to gdrivers)
>>     - autotest2/ogr/geojson_test.py
>>     <https://gist.github.com/schwehr/6cbdc3482055d2237ad2>
>>     Probably should move python code to also match the C++ tree.  e.g.
>>         tiff_read_test.py -> autotest2/py/frmts/gtiff/tiff_read_test.py
>>     I'm (mostly) following Google's style guides.  Public versions
>>     here: C++
>>     <https://google-styleguide.googlecode.com/svn/trunk/cppguide.html> Python
>>     <https://google-styleguide.googlecode.com/svn/trunk/pyguide.html>
>>     All C++ should be formatted with "clang-format --style=Google"
>>     What does autotest2 not do?
>>     Would like to eventually do (unsorted):
>>     - Test error handling on a range of corrupt data sources
>>     - Fuzz testing, ASAN/MSAN/TSAN/Valgrind/Heap checks  (I've done
>>     some MSAN & heap checkers by hand)
>>     - Performance testing - time and memory usage
>>     - Test the C API at the C level
>>     - Test platforms other than Linux (MS Win*, Mac OSX, Android,
>>     iOS, other embedded oses, BSD*, Solaris, HPUX, etc)
>>     - Have more detailed language binding tests for java, ruby, perl, php
>>     - Coverage checking
>>     - Test parallel processing and multithreading
>>     - Test networking (I need to think through isolation)
>>     - Test multiple configurations (e.g. all drivers and features
>>     enables vrs minimal build).
>>     - Check which system calls are used by each driver for read and
>>     for write
>>     - Check i18n support.
>>     - Check distribution packaging
>>     - Validating that the given build options result in the expect
>>     available features
>>     Probably out of scope:
>>     - Test for support from older platforms & C++ older than C++11
>>     - Actual sandbox checks
>>     - Test other bindings to GDAL's C or C++ API such as Fiona & Shapely
>>     - Integration tests (e.g. GRASS, QGIS, mapserv, GeoDjango, etc).
>>     - ABI compatibility checks
>>     - Older versions of dependent libs e.g. netcdf/hdf4/5, kakadu,
>>     openjpeg, etc.
>>     -kurt
>>     Engineer at Google
>>     On Sat, Sep 5, 2015 at 7:48 AM, Dmitry Baryshnikov
>>         Hi Even,
>>         05.09.2015 17:10, Even Rouault пишет:
>>             Dmitry,
>>                 During the code sprint in FOSS4G 2015 (Korea, Seoul)
>>                 I plan to start
>>                 refactoring Cmake for GDAL (everybody are welcome
>>                 http://2015.foss4g.org/programme/code-sprint/). This
>>                 is good starting
>>                 point to try release an idea to reformat source tree
>>                 (combine drivers on
>>                 some principles - raster/vector/raster+vector). I
>>                 digging the mailing
>>                 list, but didn't found discussion started by Even
>>                 about this.
>>             Regarding unified drivers, it was a bit mentionned in
>>             https://trac.osgeo.org/gdal/wiki/rfc46_gdal_ogr_unification
>>             . Basically the
>>             PCIDSK drivers have been merged in frmts/pcidsk, the PDF
>>             ones in frmts/pdf.
>>             And the raster side of GPKG has been added to the existing
>>             ogr/ogrsf_frmts/geopackage
>>             Potential changes on the tree structure were left out in
>>             the "Potential
>>             changes that are *NOT* included in this RFC" paragraph.
>>         I plan to experiment with this and if I get good results, RFC
>>         will be written.
>>                 Also we have
>>                 new type of drivers - network. So, how it'll be best
>>                 to organise sources?
>>                 This can be not only drivers, but the whole source
>>                 tree. How should the
>>                 ideal GDAL source tree looks like?
>>                 Also I plan:
>>                 1. Move all internal libraries (zlib, libtiff,
>>                 libjpeg, etc.) to
>>                 separate github repos to use CMake ExternalProject
>>                 feature.
>>             Just to give some context: the point for the internal
>>             libraries was to have a
>>             no-brainer way of building GDAL without any prerequisite.
>>             - internal zlib is identical to its upstream v1.2.3 AFAIK
>>             - internal libtiff: most files are identical to libtiff
>>             CVS, but a few ones
>>             (tiffconf.h, tif_config.h) have been modified for
>>             integration with GDAL CPL, and
>>             tif_vsi.c is GDAL specific (I/O implementation) + a build
>>             time hack for TIFF
>>             JPEG 12 bit support
>>             - internal libjpeg is mostly upstream libjpeg v6b + one
>>             patch. There's also
>>             the build hack for libjpeg12
>>         I only plan to move this internal libraries in separate
>>         repos, not to link official ones. So this is only give more
>>         structured sources tree.
>>                 2. Remove any other building systems
>>             That sounds ambitious. Given the complexity and maturity
>>             of our current build
>>             systems, I guess this would take some time to have CMake
>>             catch up.
>>         Yes, certainly. But anyhow current CMake branch not fully
>>         consistent for current build system. So this have to be done.
>>                 3. Try CTest for testing
>>             What do you think it will bring w.r.t our current testing
>>             system ? Do we want
>>             to be dependant of a particular build system for our tests ?
>>             Regarding testing, I've somehow understood Kurt had
>>             mentionned plans for a
>>             "gdalautotest2"
>>         This is only subject of experiments. Let's try CTest and see
>>         if it fits.
>>             Regarding all the above, I assume you mean in a fork of
>>             yours ?
>>         Yes. All experiments will be on forked GDAL in separate branch.
>>                 As for me the ideal structure should looks like:
>>                 + apps
>>                 + autotests
>>                 + bindings
>>                 + core
>>                     + port
>>                     + ogr
>>                     + gcore
>>             gnm core would go here too ?
>>         Yes
>>                 + cmake
>>                 + data
>>                 + docs
>>                     + doxygen
>>                     + readme
>>                 + drivers
>>                     + raster
>>                     + vector
>>                     + network
>>                     + combined
>>                 + CMakeLists.txt
>>                 + LICENSE
>>                 So, at the root of sources tree we will have only 8
>>                 folders and 2 files.
>>             Is the churn in the tree structure worth the effort ? Be
>>             aware that there are a
>>             number of interdependencies between drivers, so this
>>             might require fixing a
>>             number of source files. What advantages do you see in a
>>             new structure ?
>>         1. More ease to understand sources tree for novice.
>>         2. More useful for CMake macro. In current release there are
>>         a lot of hardcoded things. Macro give more flexibility.
>>         3. More ease to add some new check needed by separate drivers.
>>         4. More configurable (ease selected depended libraries
>>         installed in OS, or should be loaded via ExternalProject),
>>         more dependence checks.
>>         5. May be CPack using in future to create distros.
>>             I'm afraid that if you want to change multiple things at
>>             a time (build system,
>>             testing mechanisms, tree structure), you will never
>>             manage to get a working
>>             result. Incremental approaches when feasible are less
>>             risky (but admitedly
>>             involve potentially a larger cumulated effort).
>>         Yes, you may be right. But it seems to me that current Cmake
>>         version is too complicated than it can be. If Ican improve it
>>         it'll solve lot of problems, if not - ok this will be only an
>>         unsuccessful experiment.
>>             Even
>>         I do not insist, maybe it's a crazy idea. But as was the
>>         discussion of unification, it seemed to me that this worth
>>         trying during improvements Cmake build system.
>>         Best regards,
>>             Dmitry
> http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150915/be50087c/attachment-0001.html>
