[gdal-dev] ogr2ogr convert geojson to MapInfo tab
Maxime Demers burton449geo at gmail.com
Thu Sep 17 09:21:24 PDT 2015
Hi Even,
Sorry to reply you in a new thread. I have realize my mail-list settings
was set to not send me replies. I have found your reply in the archive.
Thank you for your answer. I am a bit desapointed that no solution exists
for now, and I dont think I would be able to test with the trunk version
because I am on windows and dont know how to build gdal from sources.
Do you have an idea, if the solution could be merged into a binary release
for windows soon?
Salutations,
Maxime Demers
<http://www.lastfm.fr/user/burton449>
>* Hello,
*> >* I encounter a problem using ogr2ogr (from gdal 1.10) when trying
to convert
*>* a geojson to MapInfo Tab. The output MapInfo tab does not include the
*>* projection wich is defined in the geojson as EPSG:3857 so srs is defined as
*>* WGS84 as default.
*> >* I think its a known problem with MapInfo Tab (mitab driver) but
I dont know
*>* if a solution exist. Anybody can help?*
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150917/25ad5df9/attachment.html>
