[gdal-dev] Generating 200x200 tiles
Homme Zwaagstra hrz at geodata.soton.ac.uk
Thu Sep 17 13:18:02 PDT 2015
Hi Alistair,
You could try ctb-tile
(https://github.com/geo-data/cesium-terrain-builder#ctb-tile) with
the`--tile-size 200` option.  This uses GDAL under the hood and works on
GDAL datasets, so pretty similar to gdal2tiles.
Best regards,
Homme.
On 17/09/15 19:03, Alistair Young wrote:
> I’ve been using gdal2tiles to generate zoom levels and tiles and it’s
> working fine but unfortunately the tiles are 256x256 and don’t work
> with the UK Ordnance Survey mapping SDK, which requires 200x200 tiles.
> Is there a way to generate these 200x200 tiles? I can generate them
> using gdal_retile but it can’t generate the zoom levels.
> Thanks,
> Alistair
> mov eax,1
> mov ebx,0
> int 80
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150917/64fdf64e/attachment.html>
