[gdal-dev] Handling pdfium build / integration
Even Rouault even.rouault at spatialys.com
Fri Sep 18 05:02:14 PDT 2015
> ar: creating ./libbigint.a.new
> ar: BigInteger.o: No such file or directory
> ar: creating ./libfx_libopenjpeg.a.new
> ar: bio.o: No such file or directory
> ar: creating ./libfx_libjpeg.a.new
> ar: fpdfapi_jcapimin.o: No such file or directory
> ar: creating ./libfx_lcms2.a.new
> ar: cmscam02.o: No such file or directory
> ar: creating ./libfx_zlib.a.new
> ar: adler32.o: No such file or directory
> ar: creating ./libfreetype.a.new
> ar: cff.o: No such file or directory
> ar: creating ./libfx_agg.a.new
> ar: agg_curves.o: No such file or directory
Yes, I do also get those errors, but they can be ignored. Perhaps the build
scrip could be improved to hide that.
> ./configure --with-pdfium=/home/bradh/pdfium/install
> I tried to remove that part, and then it looks like its OK, although gdal
> complains about CFDF_Document::CreateNewDoc being hidden when I build.
And if you just let the script run ? That works for me (GCC 4.7.0)
Oh, I've just edited the script to default to Release mode instead of Debug.
> So I guess I'm still doing something wrong.
> Brad
http://www.spatialys.com
