[gdal-dev] ogr2ogr convert geojson to MapInfo tab
Maxime Demers burton449geo at gmail.com
Fri Sep 18 06:45:20 PDT 2015
My bad, I realize I have installed Gdal core from gisinternals using
gdal-201-1600-core.msi but this file is dated of 2015-07-30. I did not
realize the core installer were not up to date. Now using the version form
release-1600-gdal-mapserver.zip I confirm that the result is good!
Thank you Even!
On Fri, Sep 18, 2015 at 9:27 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le vendredi 18 septembre 2015 15:08:31, Maxime Demers a écrit :
> > Hi Even,
> > I just proceeded to test the conversion from geojson to mapInfo tab with
> > the latest build. The result is not good.
> Maxime,
> Which binary did you use ?
> If that works, that will report :
> PROJCS["WGS 84 / Pseudo-Mercator",
>     GEOGCS["unnamed",
>         DATUM["WGS_1984",
>             SPHEROID["WGS 84 (MAPINFO Datum
> 157)",6378137.01,298.257223563],
>             TOWGS84[0,0,0,0,0,0,0]],
>         PRIMEM["Greenwich",0],
>         UNIT["degree",0.0174532925199433]],
>     PROJECTION["Mercator_1SP"],
>     PARAMETER["central_meridian",0],
>     PARAMETER["scale_factor",1],
>     PARAMETER["false_easting",0],
>     PARAMETER["false_northing",0],
>     UNIT["Meter",1.0],
>     EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
> +lon_0=0.0
> +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext  +no_defs"]]
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Stack Overflow: http://stackoverflow.com/users/1914034/burton449
GIS Overflow: http://gis.stackexchange.com/users/14426/burton449
LastFm: http://www.lastfm.fr/user/burton449
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150918/b2f416ab/attachment.html>
