[gdal-dev] Installation prefix for Python bindings on MacOSX ?
William Kyngesburye woklist at kyngchaos.com
Sun Sep 20 08:24:18 PDT 2015
/Library/Python/[version]/site-packages is the standard user path for OS X.  /usr/lib is not in the python path.  Even if you add /usr/lib to the Travis setup, the installation will still be broken for general use.
On Sep 20, 2015, at 10:09 AM, Even Rouault <even.rouault at spatialys.com> wrote:
> Hi,
> Antonio has contributed a fix in https://trac.osgeo.org/gdal/ticket/4563 to
> make the Python bindings honour the installation prefix.
> A side effect of this is that now on the MacOsX Travis instance, they are
> installed in /usr/lib/python2.7/site-packages whereas previously they were
> installed in /Library/Python/2.7/site-packages
> But it appears that they are not found automatically when in
> /usr/lib/python2.7/site-packages. Is it expected ? Should we define PYTHONPATH
> to /usr/lib/python2.7/site-packages in thre Travis script (
> https://github.com/rouault/gdal_coverage/blob/trunk_travis_macosx/.travis.yml
> Before change: https://travis-ci.org/rouault/gdal_coverage/builds/81193480
> New behaviour: ​https://travis-ci.org/rouault/gdal_coverage/builds/81242249
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either.  Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
