[gdal-dev] How to merge tile trees
Ari Jolma ari.jolma at gmail.com
Tue Sep 22 22:48:23 PDT 2015
Dash,
I have only a limited experience with tiles and gdal2tiles, so I'm not
sure the correctness of this but anyway. I'd also like to see if I have
understood correctly, so please anybody correct if I'm wrong.
The tiles are in a two-level directory tree, where the top level has the
zoom level and the one below that has a number, which I assume is some
kind of global location reference. Within that there are the tiles,
which have a name, which, I assume, are some kind of global location
reference. For example I have this:
9
     286
10
     573
If you have two trees, which have the same original data, then I assume
it is a simple directory copy to merge them.
Also, gdal2tiles seems to detect, which tiles you have and only recreate
the missing ones when run twice with the same command line.
Best,
Ari
On 22.09.2015 21:33, Dash wrote:
> Hey folks,
> I have a slight problem that is stumping me.  I created  a large set of
> tiles using gdal2tiles only to notice that I was missing 2 images.  So,
> instead of creating all new tiles I created a set of tiles (with the same
> extent) for just the 2 missing images.  However, now I don't know how to
> merge the 2 tile trees.  The output from gdal2tiles creates images with the
> exact same name, so is it even possible to merge to 2 tile sets?
> I hope my explanation makes sense.
> Thanks...
> View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-merge-tile-trees-tp5225493.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
