[gdal-dev] Installation error messages on Mac OS 10.10.5 Yosemite
Phillips-Alonge, Kristin Eileen kephill at sandia.gov
Mon Sep 28 07:21:16 PDT 2015
Hello,
I am trying to install GDAL-2.0.1 on a Mac OS 10.10.5 and received some error messages.  I modified setup.cfg to point to the location of gdal_config after installing the gdal library (1.11.2_3) with homebrew.
These are some of the error messages I’m getting when I type “python setup.py build” in the distribution directory of GDAL-2.0.1.  Any ideas of what I can do to resolve this?  I do not have easy_install for Python and was not able to install pip for the installation of packages because I use a proxy server and have a password containing ‘#' which cuts off the rest of the password from being read.
warning: unknown warning option
      '-Werror=unused-command-line-argument-hard-error-in-future'; did you mean
      '-Werror=unused-command-line-argument'? [-Wunknown-warning-option]
extensions/gdal_wrap.cpp:2230:11: warning: explicitly assigning value of
      variable of type 'int' to itself [-Wself-assign]
                    res = SWIG_AddCast(res);
extensions/gdal_wrap.cpp:2233:11: warning: explicitly assigning value of
extensions/gdal_wrap.cpp:4265:47: error: use of undeclared identifier
      'GDALDatasetCreateLayer'; did you mean 'GDALDatasetShadow_CreateLayer'?
    OGRLayerShadow* layer = (OGRLayerShadow*) GDALDatasetCreateLayer( self,
extensions/gdal_wrap.cpp:4264:28: note: 'GDALDatasetShadow_CreateLayer' declared
      here
SWIGINTERN OGRLayerShadow *GDALDatasetShadow_CreateLayer(GDALDatasetShad...
extensions/gdal_wrap.cpp:4273:47: error: use of undeclared identifier
      'GDALDatasetCopyLayer'
    OGRLayerShadow* layer = (OGRLayerShadow*) GDALDatasetCopyLayer( self,
extensions/gdal_wrap.cpp:4280:12: error: use of undeclared identifier
      'GDALDatasetDeleteLayer'; did you mean 'GDALDatasetShadow_DeleteLayer'?
    return GDALDatasetDeleteLayer(self, index);
extensions/gdal_wrap.cpp:4279:19: note: 'GDALDatasetShadow_DeleteLayer' declared
      here
SWIGINTERN OGRErr GDALDatasetShadow_DeleteLayer(GDALDatasetShadow *self,...
extensions/gdal_wrap.cpp:4306:8: error: use of undeclared identifier
      'OGRERR_NON_EXISTING_FEATURE'
  case OGRERR_NON_EXISTING_FEATURE:
extensions/gdal_wrap.cpp:4314:12: error: use of undeclared identifier
      'GDALDatasetGetLayerCount'; did you mean
      'GDALDatasetShadow_GetLayerCount'?
    return GDALDatasetGetLayerCount(self);
extensions/gdal_wrap.cpp:4313:16: note: 'GDALDatasetShadow_GetLayerCount'
      declared here
SWIGINTERN int GDALDatasetShadow_GetLayerCount(GDALDatasetShadow *self){
extensions/gdal_wrap.cpp:4318:47: error: use of undeclared identifier
      'GDALDatasetGetLayer'
    OGRLayerShadow* layer = (OGRLayerShadow*) GDALDatasetGetLayer(self, index);
extensions/gdal_wrap.cpp:4322:47: error: use of undeclared identifier
      'GDALDatasetGetLayerByName'; did you mean
      'GDALDatasetShadow_GetLayerByName'?
  ...layer = (OGRLayerShadow*) GDALDatasetGetLayerByName(self, layer_name);
extensions/gdal_wrap.cpp:4321:28: note: 'GDALDatasetShadow_GetLayerByName'
      declared here
SWIGINTERN OGRLayerShadow *GDALDatasetShadow_GetLayerByName(GDALDatasetS...
extensions/gdal_wrap.cpp:4326:13: error: use of undeclared identifier
      'GDALDatasetTestCapability'; did you mean
      'GDALDatasetShadow_TestCapability'?
    return (GDALDatasetTestCapability(self, cap) > 0);
extensions/gdal_wrap.cpp:4325:17: note: 'GDALDatasetShadow_TestCapability'
      declared here
SWIGINTERN bool GDALDatasetShadow_TestCapability(GDALDatasetShadow *self...
extensions/gdal_wrap.cpp:4336:47: error: use of undeclared identifier
      'GDALDatasetExecuteSQL'; did you mean 'GDALDatasetShadow_ExecuteSQL'?
    OGRLayerShadow* layer = (OGRLayerShadow*) GDALDatasetExecuteSQL(self,
extensions/gdal_wrap.cpp:4335:28: note: 'GDALDatasetShadow_ExecuteSQL' declared
      here
SWIGINTERN OGRLayerShadow *GDALDatasetShadow_ExecuteSQL(GDALDatasetShado...
extensions/gdal_wrap.cpp:4343:5: error: use of undeclared identifier
      'GDALDatasetReleaseResultSet'; did you mean
      'GDALDatasetShadow_ReleaseResultSet'?
    GDALDatasetReleaseResultSet(self, layer);
extensions/gdal_wrap.cpp:4342:17: note: 'GDALDatasetShadow_ReleaseResultSet'
      declared here
SWIGINTERN void GDALDatasetShadow_ReleaseResultSet(GDALDatasetShadow *se...
extensions/gdal_wrap.cpp:4346:35: error: use of undeclared identifier
      'GDALDatasetGetStyleTable'; did you mean
      'GDALDatasetShadow_GetStyleTable'?
    return (OGRStyleTableShadow*) GDALDatasetGetStyleTable(self);
extensions/gdal_wrap.cpp:4345:33: note: 'GDALDatasetShadow_GetStyleTable'
      declared here
SWIGINTERN OGRStyleTableShadow *GDALDatasetShadow_GetStyleTable(GDALData...
extensions/gdal_wrap.cpp:4350:9: error: use of undeclared identifier
      'GDALDatasetSetStyleTable'; did you mean
      'GDALDatasetShadow_SetStyleTable'?
        GDALDatasetSetStyleTable(self, (OGRStyleTableH) table);
extensions/gdal_wrap.cpp:4348:17: note: 'GDALDatasetShadow_SetStyleTable'
      declared here
SWIGINTERN void GDALDatasetShadow_SetStyleTable(GDALDatasetShadow *self,...
extensions/gdal_wrap.cpp:4350:40: error: cannot initialize a parameter of type
      'OGRStyleTableShadow *' (aka 'OGRStyleTableHS *') with an rvalue of type
      'OGRStyleTableH' (aka 'void *')
extensions/gdal_wrap.cpp:4348:94: note: passing argument to parameter 'table'
      here
  ...*self,OGRStyleTableShadow *table){
extensions/gdal_wrap.cpp:4353:12: error: use of undeclared identifier
      'GDALDatasetStartTransaction'; did you mean
      'GDALDatasetShadow_StartTransaction'?
    return GDALDatasetStartTransaction(self, force);
extensions/gdal_wrap.cpp:4352:19: note: 'GDALDatasetShadow_StartTransaction'
      declared here
SWIGINTERN OGRErr GDALDatasetShadow_StartTransaction(GDALDatasetShadow *...
extensions/gdal_wrap.cpp:4356:12: error: use of undeclared identifier
      'GDALDatasetCommitTransaction'; did you mean
      'GDALDatasetShadow_CommitTransaction'?
    return GDALDatasetCommitTransaction(self);
extensions/gdal_wrap.cpp:4355:19: note: 'GDALDatasetShadow_CommitTransaction'
      declared here
SWIGINTERN OGRErr GDALDatasetShadow_CommitTransaction(GDALDatasetShadow *self){
extensions/gdal_wrap.cpp:4359:12: error: use of undeclared identifier
      'GDALDatasetRollbackTransaction'; did you mean
      'GDALDatasetShadow_RollbackTransaction'?
    return GDALDatasetRollbackTransaction(self);
extensions/gdal_wrap.cpp:4358:19: note: 'GDALDatasetShadow_RollbackTransaction'
      declared here
SWIGINTERN OGRErr GDALDatasetShadow_RollbackTransaction(GDALDatasetShado...
extensions/gdal_wrap.cpp:4361:294: error: unknown type name
      'GDALRIOResampleAlg'; did you mean 'GDALResampleAlg'?
  ...*buf_line_space=0,GIntBig *buf_band_space=0,GDALRIOResampleAlg resample_...
                                                 GDALResampleAlg
/usr/local/Cellar/gdal/1.11.2_3/include/gdalwarper.h:56:3: note:
      'GDALResampleAlg' declared here
} GDALResampleAlg;
extensions/gdal_wrap.cpp:4361:326: error: use of undeclared identifier
      'GRIORA_NearestNeighbour'; did you mean 'GRA_NearestNeighbour'?
  ...resample_alg=GRIORA_NearestNeighbour,GDALProgressFunc callback=NULL,voi...
/usr/local/Cellar/gdal/1.11.2_3/include/gdalwarper.h:49:56: note:
      'GRA_NearestNeighbour' declared here
  /*! Nearest neighbour (select on one input pixel) */ GRA_NearestNeighbour=0,
extensions/gdal_wrap.cpp:4425:5: error: unknown type name 'GDALRasterIOExtraArg'
    GDALRasterIOExtraArg sExtraArg;
fatal error: too many errors emitted, stopping now [-ferror-limit=]
4 warnings and 20 errors generated.
error: command '/usr/bin/clang' failed with exit status 1
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150928/9a0816f1/attachment-0001.html>
