[gdal-dev] How to deal with IIP image via WMS minidriver?
Even Rouault even.rouault at spatialys.com
Tue Sep 29 01:27:14 PDT 2015
Carlo,
I've just committed in GDAL trunk a IIP mini driver. Requires a IIP server
that supports the JTL extension (which was the case for the 2 online services I tested).
Online doc at http://www.gdal.org/frmt_wms.html will be refreshed in a few hours.
A few demos:
$ gdalinfo "IIP:http://merovingio.c2rmf.cnrs.fr/fcgi-bin/iipsrv.fcgi?FIF=globe.256x256.tif"
Driver: WMS/OGC Web Map Service
Files: none associated
Size is 86400, 43200
Coordinate System is `'
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,43200.0)
Upper Right (86400.0,    0.0)
Lower Right (86400.0,43200.0)
Center      (43200.0,21600.0)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
  Overviews: 43200x21600, 21600x10800, 10800x5400, 5400x2700, 2700x1350, 1350x675, 675x337, 337x168, 168x84
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
$ gdal_translate -of WMS  "IIP:http://merovingio.c2rmf.cnrs.fr/fcgi-bin/iipsrv.fcgi?FIF=globe.256x256.tif" globe.wms
$ cat globe.wms
<GDAL_WMS>
  <Service name="IIP">
    <ServerUrl>http://merovingio.c2rmf.cnrs.fr/fcgi-bin/iipsrv.fcgi?FIF=globe.256x256.tif</ServerUrl>
  </Service>
  <DataWindow>
    <SizeX>86400</SizeX>
    <SizeY>43200</SizeY>
    <TileLevel>9</TileLevel>
  </DataWindow>
  <BlockSizeX>256</BlockSizeX>
  <BlockSizeY>256</BlockSizeY>
  <BandsCount>3</BandsCount>
  <Cache />
</GDAL_WMS>
$ gdal_translate globe.wms out.tif -outsize 1024 0 -r bilinear
Best regards,
Even
> Dear Petr,
> I'm very fond of georeferencer.com; for many topographic and geographic
> maps it's more effective than using a desktop application like QGIS.
> The idea of implementing IIP/IIIF inside gdal has several reasons.
> The first one is due to rights over the images. They are meant for personal
> use, sometimes institutions are bound to contracts with private firms that
> would not allow them to put these on georeferencer (I'm strongly againt
> these agreements, but they are here to stay...), so hosting them elsewhere
> would be at least embarassing if not illegitimate (there should also be a
> way to open an arbitrary souce besides uploaded images, which is not the
> case).
> Another one is the ability of comparing historical maps one with another,
> which is sometimes useful, besides a comparison between an unreferenced
> image and Google Maps/Osm. Sometimes being able to use another reference,
> say a cadastral map or a very detailed one is compelling (which is a third
> reason).
> I think that an alternative way to use IIP/IIIF may be useful and in the
> spirit of and Open Source project as gdal.
> It's obviously easy to download the tiles one by one (jot/curl) and
> assemble them in a sometimes huge file (montage), but a more dynamic way is
> a must in these cases. Evan confirmed it would be fairly easy modifying the
> WMS mini-driver to do it, but I think a pseudo-referenced (by pixel) VRT
> file could be forged (as a temporary provision), knowing the number of
> tiles in a row (easy to do) and the number of rows. I'll try to raise some
> funding for the project to help in this development. Meanwhile, if someone
> would like to try doing something on it, I'll be grateful and I will try to
> support this effort even afterwards.
> c
> On Tue, Sep 15, 2015 at 12:12 AM, Petr Pridal <petr.pridal at klokantech.com>
> wrote:
> > Dear Carlo,
> > if you use our Georeferencer.com online service we can provide you with a
> > fast OGC WMTS service and crowdsourced online georeferencing of the
> > remote image sources such as IIIF or IIP done in a web browser.
> > Best regards,
> > Petr
> > On Thu, Sep 3, 2015 at 5:17 PM, Carlo A. Bertelli (Charta s.r.l.) <
> > bertelli at chartasrl.eu> wrote:
> >> Hello,
> >> is there a way -- maybe using the WMS minidriver -- to open an IIP
> >> streamed picture?
> >> The online service is well documented (
> >> http://iipimage.sourceforge.net/documentation/) but unfortunately it
> >> shows that the protocol is not at all compliant with the WMTS or TMS or
> >> Google/SlippyMap schemas, even if it shares some of the ideas behind
> >> them. There is an also an implementation of a plugin for Leaflet that
> >> could help. Would anyone give some advice on how to deal with this
> >> common raster map source for historical maps?
> >> c
http://www.spatialys.com
