[gdal-dev] Improving ogr dxf driver spline reader
Even Rouault even.rouault at spatialys.com
Fri Apr 1 10:55:12 PDT 2016
Le vendredi 01 avril 2016 19:36:41, Pero Brbora a écrit :
> Hi,
> I would like to improve ogr dxf driver spline reader. I have created
> few test files and found mistakes in source code. Current spline
> reader creates splines only from control points, and then tries to
> recreate knots and sets weights to 1. From my understanding of splines
> they are completely defined with control points, knots and weights -
> and all this data can be read from dxf file.
> Is it ok to:
> first) submit ticket with description and test files
> second)
Screenshots of a reader that correctly displays the splines attached to the
ticket can be useful to check that the proposed fix looks good.
> submit pull request which targets autotest part of gdal and
> adds tests which show that current implementation fails
> third) submit pull request which targets ogr dxf dxf driver and fixes
> all of the above
The usual practice is a single pull request with driver fix + small samples +
new tests with the (fixed) expected result (and/or fixes to existing tests that
would have been wrong previously)
> Is this correct approach for contributing to gdal?
> Thanks, bye
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
