[gdal-dev] GDAL packaging in OSGeo4W
Tamas Szekeres szekerest at gmail.com
Wed Apr 6 13:17:57 PDT 2016
Hi Jürgen,
Is that possible to include further plugins in the gdal-dev build?
I'm interested in adding the new ogr_MSSQLSpatial.dll plugin build as an
optional component? Though it requires the SQL Server native client 11
driver installed on the build machine. I could add this package manually,
but I'm not sure if that satisfies with the intent that these are nightly
build packages. Since this plugin depends on sqlncli11.dll the package
description should mention the requirement to install the SQL Server native
client 11 driver as a prerequisite.
in nmake.opt the followings should be enabled when compiling the plugin:
SQLNCLI_VERSION = 11
SQLNCLI_DIR = C:\Program Files (x86)\Microsoft SQL
Server\$(SQLNCLI_VERSION)0\SDK
SQLNCLI_LIB = "$(SQLNCLI_DIR)\Lib\x86\sqlncli$(SQLNCLI_VERSION).lib"
SQLNCLI_INCLUDE = "-I$(SQLNCLI_DIR)\Include"
-DSQLNCLI_VERSION=$(SQLNCLI_VERSION) -DMSSQL_BCP_SUPPORTED=1
Thanks,
Tamas
2016-04-06 18:37 GMT+02:00 Jürgen E. <jef at norbit.de>:
> Hi Even,
> On Mon, 22. Feb 2016 at 12:15:31 +0100, Even Rouault wrote:
> > Could be cool to have -dev versions packaged from time to time (or
> potentially
> > nightly builds), as well as a few drivers available as plugins (PDF
> driver,
> > MongoDB one)
> There's a nighly build of GDAL in OSGeo4W now.   Invoke gdal-dev-env from
> the
> osgeo4w shell to setup it's paths.
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel.
> +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
> +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160406/338b5230/attachment.html>
