[gdal-dev] Change in parsing of OGR where clause
Even Rouault even.rouault at spatialys.com
Wed Apr 6 13:57:19 PDT 2016
Le mercredi 06 avril 2016 22:48:38, Andrew Bell a écrit :
> On Wed, Apr 6, 2016 at 3:39 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Andrew,
> > > In version 1.X of GDAL, the following was accepted and worked:
> > > std::string query = "LOCATION=\"some text\"";
> > > OGR_L_SetAttributeFilter(layer, query.c_str());
> > > In version 2.X, this is no longer accepted and the double quotes must
> > > be replaced by single quotes:
> > > std::string query = "LOCATION='some text'";
> > > This wouldn't be awful, but the error that occurs tells you nothing
> > > about the actual problem.  It yields:
> > > "some text" not recognised as an available field.
> > Well, I find the message quite clear : "some text" isn't an recognized
> > field :-)
> Is there a context where a double-quoted string would be acceptable here?
> If so, then fine (maybe).  But if not, it seems that something like
> "unexpected character '"' found in where clause" would make more sense than
> the current message.
Well, there are cases where your datasource could have field names that require
double quoting. It is generally not possible to distinguish the cases where
the user wanted to specify a field name but get it wrong, from the cases where
he wanted to specify a string literal. If you try with another SQL engine,
you'd have similar messages :
$ ogrinfo pg:dbname=autotest -sql "select * from poly where eas_id = \"some
text""
INFO: Open of `pg:dbname=autotest'
      using driver `PostgreSQL' successful.
ERROR 1: ERROR: the column « some text » does not exist
LINE 1: ...SQLCursor CURSOR for select * from poly where eas_id = "some text"
> I'm not grumbling about the change, but it took me a while to track down :(
>   A different error message would have helped greatly.
Yes, I can understand that. I encourage everybody looking at the
MIGRATION_GUIDE when they upgrade their version :
https://svn.osgeo.org/gdal/trunk/gdal/MIGRATION_GUIDE.TXT
> Thanks,
http://www.spatialys.com
