[gdal-dev] ogr2ogr failing on postgis?
Even Rouault even.rouault at spatialys.com
Sun Apr 10 12:06:20 PDT 2016
Le dimanche 10 avril 2016 20:39:25, Paolo Cavallini a écrit :
> Il 10/04/2016 18:01, Even Rouault ha scritto:
> > Yes, this is expected and a rather common problem with shapefiles.
> Thanks a lot for the explanation. QGIS therefore creates an incorrect
> prj, but I did not noticed it because it loaded it with the correct
> EPSG. Ticket upstream opened:
> http://hub.qgis.org/issues/14655
No, QGIS did it fine (actually I suspect it generates .prj file through OGR
itself). ESRI .prj file are supposed *not* to contain EPSG codes unfortunately.
This is the ESRI WKT variant. Which makes it hard to deal with them on the
reading side. The issue is more on the OGR side.
http://www.spatialys.com
