[gdal-dev] GDAL 2.1 Beta and GRASS 7.0.4
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Mon Apr 11 01:26:50 PDT 2016
Thanks for your swift reply! That was it.
Error messages gone and all fine now!
Thanks!
Kind regards,
Stefan
-----Original Message-----
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: 11. april 2016 10:01
To: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] GDAL 2.1 Beta and GRASS 7.0.4
Le lundi 11 avril 2016 09:13:06, Blumentrath, Stefan a écrit :
> Hi again,
> One more question:
> Before I installed GDAL 2.1 with GRASS 7.0.4svn support I ran GDAL
> 1.11 compiled against GRASS 7.0.2.
> Now I get on every GDAL command this: error message:
> ERROR 1: libgrass_gis.7.0.2svn.so: cannot open shared object file: No
> such file or directory ERROR 1: libgrass_gis.7.0.2svn.so: cannot open
> shared object file: No such file or directory ERROR 1:
> libgrass_raster.7.0.2svn.so: cannot open shared object file: No such
> file or directory ERROR 1: libgrass_raster.7.0.2svn.so: cannot open
> shared object file: No such file or directory Warning 1: GRASS
> warning: GISBASE environment variable was not set, using:
> /usr/local/grass-7.0.4svn
> Driver: GRASS/GRASS Rasters (5.7+)
If you had GRASS support as a plugin of GDAL 1.11 installed in /usr/local/share/gdalplugins, I guess this messages comes from the plugin when GDAL 2.1 tries to load it.
Spatialys - Geospatial professional services http://www.spatialys.com
