[gdal-dev] MBTiles Error
Miller, Doug dmiller at JFTI.com
Fri Apr 15 06:34:59 PDT 2016
I've got several files of MBTiles format that are from the an external source.  I'm using the 2.0.2 version of GDAL.  When opened by the gdalinfo CLI tool or the MBTiles driver they all have the same errors:
Error 1: Invalid value for 'bounds' metadata
Error 1: Cannot find min and max tile numbers
gdalinfo failed- unable to open.......
????Other MBTiles files from the same publisher open just fine.
Is there a way to fix or override this metadata?
It looks like GDAL 2.2 will allow these parameters to be overridden, but I can't use a beta version in my product and the final release looks like it could be 4 months from now.
Thanks for any help.
Doug
