[gdal-dev] Shapefile to SQL Server
Tamas Szekeres szekerest at gmail.com
Fri Apr 15 09:21:48 PDT 2016
Looks like you have invalid latitude values in the shapefile. Try creating
geometry type instead of geography.
Best regards,
Tamas
2016-04-15 17:06 GMT+02:00 Mike Colbert <mcolbert at unicon-intl.com>:
> Hi,
> I have a Java web app with a SQL Server database and I would like to add
> support for importing shapefiles.  The shapes will then be used to
> determine if geographic locations we have defined in our system are within
> the areas defined by the shapes.
> I’ve gone down the path of using ogr2ogr from Java to connect to SQL
> Server and load the shapefile.  However, I’m getting an error on a
> particular file I will need to load.  I’m wondering if I’m missing an
> option on the command?  Using a different shapefile, it seems to work.
> Here is the command and the error:
> String[] cmd = {
>                                 "-overwrite",
>                                 "-f", "MSSQLSpatial",
> "MSSQL:Server=xxx;Database=xxx;Uid=xxx;Pwd=xxx",
> "C:\\Users\\mcolbert\\Downloads\\UGRB_Ozone_NAA\\UGRB_Ozone_NAA.shp", //
> error on this one
> "C:\\Users\\mcolbert\\Downloads\\tl_2010_06_zcta510\\tl_2010_06_zcta510.shp",
> // this one seems fine
>                                 "-lco", "GEOM_TYPE=geography",
>                                 "-lco", "GEOM_NAME=geog",
>                                 "-nln", "CM_SHAPE",
>                                 "--debug", "ON"
> //                            ,"-a_srs", "ESPG:4269"
> ogr2ogr.main(cmd);
> OGR:
> OGROpen(C:\Users\mcolbert\Downloads\UGRB_Ozone_NAA\UGRB_Ozone_NAA.shp/00000000003FFE40)
> succeeded as ESRI Shapefile.
> OGR_MSSQLSpatial:
> EstablishSession(Connection:"Server=xxx;Database=xxx;Uid=xxx;Pwd=xxx")
> ODBC: SQLDriverConnect(DRIVER=SQL
> Server;Server=xxx;Database=xxx;Uid=xxx;Pwd=xxx)
> OGR:
> OGROpen(MSSQL:Server=xxx;Database=xxx;Uid=xxx;Pwd=xxx/000000000042C440)
> succeeded as MSSQLSpatial.
> MSSQLSpatial: DeleteLayer(cm_shape)
> OGR_MSSQLSpatial: Using column ogr_fid as FID for table cm_shape.
> ERROR 1: INSERT command for new feature failed. [Microsoft][ODBC SQL
> Server Driver][SQL Server]A .NET Framework error occurred during execution
> of user-defined routine or aggregate "geography":
> System.FormatException: 24201: Latitude values must be between -90 and 90
> degrees.
>    at Microsoft.SqlServer.Types.GeographyValidator.ValidatePoint(Double x,
> Double y, Nullable`1 z, Nullable`1 m)
>    at Microsoft.SqlServer.Types.Validator.BeginFigure(Double x, Double y,
>    at Microsoft.SqlServer.Types.Forw
> Terminating translation prematurely after failed
> translation of layer UGRB_Ozone_NAA (use -skipfailures to skip errors)
> I’m assuming there is nothing unusual about the shapefile.  The file is
> available here:
> http://deq.wyoming.gov/media/attachments/Air%20Quality/Winter%20Ozone/Nonattainment%20Information/2012_AQD_UGRB-Ozone-Nonattainment-Area-GIS-Shape-File.zip
> Any help is appreciated.
> Thanks,
> Mike
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160415/41db4b53/attachment.html>
