[gdal-dev] MBTiles Error
Even Rouault even.rouault at spatialys.com
Fri Apr 15 09:37:25 PDT 2016
Le vendredi 15 avril 2016 18:27:55, Miller, Doug a écrit :
> Even,
> I tried option #1 (ogrinfo your.mbtiles -sql "DELETE FROM metadata WHERE
> name = 'bounds'") and then it came up clean with "gdalinfo" and loaded
> into QGIS correctly.
> The bad files are property that I cannot share, but I would if I could.
The output of the following would help :
ogrinfo your.mbtiles -al -sql "SELECT value FROM metadata WHERE name = 'bounds'"
> Thanks for the help,
> Doug
> ________________________________________
> From: Even Rouault <even.rouault at spatialys.com>
> Sent: Friday, April 15, 2016 9:53 AM
> To: gdal-dev at lists.osgeo.org
> Cc: Miller, Doug
> Subject: Re: [gdal-dev] MBTiles Error
> Le vendredi 15 avril 2016 15:34:59, Miller, Doug a écrit :
> > Hi,
> > I've got several files of MBTiles format that are from the an external
> > source.  I'm using the 2.0.2 version of GDAL.  When opened by the
> > gdalinfo CLI tool or the MBTiles driver they all have the same errors:
> > Error 1: Invalid value for 'bounds' metadata
> > Error 1: Cannot find min and max tile numbers
> > gdalinfo failed- unable to open.......
> > ????Other MBTiles files from the same publisher open just fine.
> > Is there a way to fix or override this metadata?
> There was a too restrictive check for the latitude range (didn't accept
> latitude above 86 deg). One workaround might be to remove the bounds
> metadata item with :
> ogrinfo your.mbtiles -sql "DELETE FROM metadata WHERE name = 'bounds'"
> or alter the extent with
> ogrinfo your.mbtiles -sql "UPDATE metadata SET value =
> 'min_long,min_lat,max_long,max_lat' WHERE name = 'bounds'" (replace
> min_long,min_lat,max_long,max_lat by actual values)
> > It looks like GDAL 2.2 will allow these parameters to be overridden, but
> > I can't use a beta version in my product and the final release looks
> > like it could be 4 months from now.
> GDAL 2.1.0 you mean ? It should be out hopefully by end of the month, with
> the first release candidate to be issued next monday. The MBTiles driver
> in it indeed improves the opening of some products that failed before.
> I'd still be interested in having access to one of those products that
> currently fail to confirm that it works fine with 2.1.0.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
