[gdal-dev] Python port newcomer
Even Rouault even.rouault at spatialys.com
Sat Apr 16 08:16:30 PDT 2016
Gregory,
You can have a look at the tickets identified by the following request
in the bug tracker:
https://trac.osgeo.org/gdal/query?status=assigned&status=new&status=reopened&description=~python&or&status=assigned&status=new&status=reopened&summary=~python&col=id&col=summary&col=status&col=type&col=priority&col=milestone&col=component&order=priority
Beware that not all of them are necessarily valid, or even sometimes
wishable to fix, or appropriate for a new comer.
You might also consult https://trac.osgeo.org/gdal/wiki/GdalOgrInPython
Even
> Hi guys!
> I'd like to work on python bindings.
> Is there anyone specifically working on it?
> Where do I start from, issues list for it, etc?
> Thanks,
> Gregory
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
