[gdal-dev] compiling gdal with hdf4
Luca Delucchi lucadeluge at gmail.com
Mon Apr 18 00:35:09 PDT 2016
Hi devs,
I'm trying to compile gdal on Centos OS with no root access, I would
like to compile it with hdf4 support. If I compile without hdf4 it
compile correctly but when I try to ad hdf4 I got the following error
(I compile libjpeg and hdf4 by myself)
/usr/bin/ld: /pico/home/usertrain/a08tra27/lib/libmfhdf.a(mfsd.o):
relocation R_X86_64_32 against `.rodata.str1.1' can not be used when
making a shared object; recompile with -fPIC
/pico/home/usertrain/a08tra27/lib/libmfhdf.a: could not read symbols: Bad value
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/pico/home/usertrain/a08tra27/gdal-2.0.2'
make: *** [check-lib] Error 2
This is the configure output
  Installation directory:    /pico/home/usertrain/a08tra27
  C compiler:                gcc -g -O2
  C++ compiler:              g++ -g -O2
  LIBTOOL support:           yes
  LIBZ support:              external
  LIBLZMA support:           no
  GRASS support:             no
  CFITSIO support:           no
  PCRaster support:          internal
  LIBPNG support:            internal
  DDS support:               no
  GTA support:               no
  LIBTIFF support:           internal (BigTIFF=yes)
  LIBGEOTIFF support:        internal
  LIBJPEG support:           internal
  12 bit JPEG:               yes
  12 bit JPEG-in-TIFF:       yes
  LIBGIF support:            internal
  OGDI support:              no
  HDF4 support:              yes
  HDF5 support:              no
  Kea support:               no
  NetCDF support:            no
  Kakadu support:            no
  JasPer support:            no
  OpenJPEG support:          no
  ECW support:               no
  MrSID support:             no
  MrSID/MG4 Lidar support:   no
  MSG support:               no
  GRIB support:              yes
  EPSILON support:           no
  WebP support:              no
  cURL support (wms/wcs/...):no
  PostgreSQL support:        no
  MySQL support:             no
  Ingres support:            no
  Xerces-C support:          no
  NAS support:               no
  Expat support:             no
  libxml2 support:           yes
  Google libkml support:     no
  ODBC support:              no
  PGeo support:              no
  FGDB support:              no
  MDB support:               no
  PCIDSK support:            internal
  OCI support:               no
  GEORASTER support:         no
  SDE support:               no
  Rasdaman support:          no
  DODS support:              no
  SQLite support:            yes
  PCRE support:              yes
  SpatiaLite support:        no
  DWGdirect support          no
  INFORMIX DataBlade support:no
  GEOS support:              yes
  Poppler support:           no
  Podofo support:            no
  OpenCL support:            no
  Armadillo support:         no
  FreeXL support:            no
  SOSI support:              no
  SWIG Bindings:             no
  Statically link PROJ.4:    yes
  enable OGR building:       yes
  enable pthread support:    yes
  enable POSIX iconv support:yes
  hide internal symbols:     no
thanks for your support
ciao
Luca
www.lucadelu.org
