[gdal-dev] Resampling a raster file with GDAL C#
Didier Bernard deedeebernard at hotmail.com
Mon Apr 18 10:59:32 PDT 2016
Hello,
I am trying to resample a .tif raster in C# GDAL in a way that every other cell in a row and column is removed.
Something similar to the lower GDAL command:
    gdal_translate -outsize 50% 0 input.tif output.tif
But this command creates a new resampled .tif file.
While I would like to avoid saving a new .tif file, and if possible just resample the dataset.
It looks like this can be achieved by the use of VRT file<http://www.gdal.org/gdal_vrttut.html>.
Here is one example of a .vrt file, which resamples the .tif file by removing the every other cell:
<VRTDataset rasterXSize="42" rasterYSize="32">
  <GeoTransform>14.3779166666, 0.000833333333333, 0.0, 40.8404166667, 0.0, -0.000833333333333</GeoTransform>
  <VRTRasterBand dataType="Byte" band="1">
    <ColorInterp>Gray</ColorInterp>
    <SimpleSource resampling="bilinear">
      <SourceFilename relativeToVRT="1">vesuvius_wgs84.tif</SourceFilename>
      <SourceBand>1</SourceBand>
      <SrcRect xOff="0" yOff="0" xSize="85" ySize="65"/>
      <DstRect xOff="0" yOff="0" xSize="42" ySize="32"/>
    </SimpleSource>
  </VRTRasterBand>
</VRTDataset>
What I noticed is that resolution of the resampled dataset does not change in comparison to the original dataset.
In this case it remains the 0.00083 degrees.
The same thing happens if I reproject the .tif file to some projected coordinate system (UTM for example): resolution remains the same (70 meters for example).
Why is this the case?
Shouldn't the resolution of the resampled dataset be twice of the resolution of the original (non-resampled) dataset, based on the fact that every other cell is removed (original dataset: 85x65, resampled dataset: 42x32)?
I would be very grateful if I could get any kind of reply.
Thank you in advance.
With kind regards,
Didier
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160418/93222d98/attachment.html>
