[gdal-dev] GDAL/OGR 2.1.0 RC1 Available for Review
Carl Godkin cgodkin at gmail.com
Mon Apr 18 11:37:32 PDT 2016
Hi Even,
There's a minor (but possibly confusing) typo in the News file at
https://trac.osgeo.org/gdal/wiki/Release/2.1.0-News
Build(Windows):
   - Add support for Visual Studio 2015 (a.k.a MSVC_VER=1900 or VC 13)
VS2015 is actually VC14, not 13.  For reasons best known to themselves,
Microsoft skipped VC13.
Thanks,
carl
On Mon, Apr 18, 2016 at 10:26 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> I have prepared a GDAL/OGR 2.1.0 release candidate. This is your
> last chance to test before the official release. There have been a number
> of
> non-trivial changes since beta1 (see diff log in Annex)
> Peek up an archive among the following ones (by ascending size):
>   http://download.osgeo.org/gdal/2.1.0/gdal-2.1.0RC1.tar.xz
>   http://download.osgeo.org/gdal/2.1.0/gdal-2.1.0RC1.tar.gz
>   http://download.osgeo.org/gdal/2.1.0/gdal210RC1.zip
> The gdal-grass plugin is available at :
>   http://download.osgeo.org/gdal/2.1.0/gdal-grass-2.1.0RC1.tar.gz
> A snapshot of the gdalautotest suite is also available :
>   http://download.osgeo.org/gdal/2.1.0/gdalautotest-2.1.0RC1.tar.gz
>   http://download.osgeo.org/gdal/2.1.0/gdalautotest-2.1.0RC1.zip
> And the documentation:
>   http://download.osgeo.org/gdal/2.1.0/gdal210doc.zip
> The NEWS file is here :
>   http://trac.osgeo.org/gdal/wiki/Release/2.1.0-News
> I'll call for a vote promoting it to final next week if no serious
> problems are
> reported.
> Best regards,
> Even
> Annex: changes since 2.1.0beta1:
> - New MRF tile format JPNG (PNG or JPEG, depending on transparency)
> - Perl bindings: fix #6431. Perl bindings: #6431. Typemaps for GIntBig and
> GUIntBig. Also fixes to two other typemaps dealing with these types.
> - A few code cleanups in frmts/raw
> - Java bindings: bump minimal java version to 1.5 in case SWIG generates
> anotations (#6433, patch by Bas Couwenberg)
> - Java bindings: disable generation of bindings for GNM as they are not
> ready
> yet (#6434)
> - SQLITE VFS: increase mxPathname to 2048 by default, and provide
> OGR_SQLITE_VFS_MAXPATHNAME config option to be able to configure that
> higher if
> that would be needed. Useful when dealing with very long names like
> /vsicurl/.... with AWS S3 security tokens
> - MBTiles: add capability to open /vsicurl/https:// signed AWS S3 URLs
> - /vsicurl/: by default do not use HEAD request when detecting a AWS S3
> signed
> URL
> - Use GDALCanFileAcceptSidecarFile() in GDALMDReaderManager::GetReader()
> - Fix GDALDefaultOverviews::OverviewScan() to properly use
> GDALCanFileAcceptSidecarFile(), and unbreak nitf_46_jasper test that
> relies on
> the OVERVIEW_FILE mechanism
> - /vsicurl/: manage redirection from public URLs to redirected AWS S3
> signed
> urls, with management of the expiration. Enabled by default. Can be
> disabled
> if CPL_VSIL_CURL_USE_S3_REDIRECT=NO (#6439)
> - configure: remove useless AC_CHECK_FUNC(setlocale) (#6438)
> - PLScenes V0: avoid opening raster to generate dummy .aux.xml
> - SQLITE VFS: do not probe -wal files on /vsicurl/
> - DXF: take into account full definition of spline entity (degree, control
> points, weights and knots) when stroking splines (#6436)
> - Shape: add capability to restore/build a missing .shx file when defining
> SHAPE_RESTORE_SHX to TRUE (#5035)
> - GRASS: fix compilation by moving C++ headers include out of extern C
> scope
> - Define HAVE_CXX11 for C++ >= 2011 compilation environments (#6432).
> - SWIG bindings: add SpatialReference.GetAxisName() and
> SpatialReference.GetAxisOrientation() (#6441)
> - gdal_translate: fix -a_nodata with negative values on rasters that have
> PIXELTYPE=SIGNEDBYTE; fix preserving PIXELTYPE=SIGNEDBYTE with VRT
> - MRF: Allow block counts larger than 2e9 by using GIntBig math
> - SWIG: add SpatialReference.GetAngularUnitsName() (#6445)
> - SWIG: partially revert r33734 and r33736 so that GetFieldIndex(name) and
> GetGeomFieldIndex(name) do not emit errors. They are the only way to check
> if
> a field exists. Particularly Python bindings use them to guess if f['foo']
> is
> an attribute field or geometry field
> - Perl bindings: GetFieldIndex should issue an error. Fix an error in STORE
> method. Add tests.
> - MBTiles: fix so that datasets whose lowest min zoom level is 16 or above
> are
> recognized
> - MBTiles: write minzoom and maxzoom metadata items
> - json_ex_get_object_by_path(): don't make it return intermediate object if
> the full path cannot be solved
> - PLScenes: fix code to work with final V1 API
> - GDALWarpOperation::CreateKernelMask(): fix potential 32 bit integer
> overflow
> when using warp memory value > 2GB (#6448)
> - ogr2ogr: fix inappropriate warning about FileGDB not being the
> appropriate
> target driver, when FileGDB is compiled as a plugin and thus registered
> before
> OpenFileGDB
> - BSB: fix compilation issues with -DBSB_CREATE
> - update mrsid driver build to find MrSID 9.5 dll
> - MBTILES / GPKG: fix generation of files with 1-band paletted input
> dataset.
> Also improve the logic to retrieve color palette when forcing BAND_COUNT=1
> on
> opening (#6450)
> - MSG: fix build with -Werror=format-security (#6451)
> - OGRParseDate(): more strict validation to reject invalide dates (#6452)
> - Fix CPLsscanf() to be conformant regarding how space/tab/... separators
> are
> handled, so as to fix OGR GMT to be able to read coordinates separated by
> tabulations (#6453)
> - gdal_translate: fix random behaviour when -scale is used without source
> bounds (#6455)
> - MBTiles: be robust to invalid 'bounds' at dataset opening (#6458)
> - MySQL: fix Windows build with recent MySQL versions and Visual Studio
> 2015
> (patch by jmckenna, #6457)
> - better handling of various object coordinate systems found in dxf files
> for
> point, line, polyline, spline and ellipse entities. Add anchor position to
> text styles. Remove polygon/polyface mesh parsing from polyline entity
> (#6459)
> - RMF: add read/write access to new RMF format for files larger than 4 Gb
> (version=0x201) (https://github.com/OSGeo/gdal/pull/11)
> - GPKG/MBTiles writer: implement strategy to flush partial_tiles temporary
> database when it becomes too big (#6462)
> - GPKG/MBTiles writer: when writing to GoogleMapsCompatible tiling scheme,
> better deal with source rasters in EPSG:4326 with latitude = +/-90 (#6463)
> - Java bindings: fix typemap for input parameter of type GIntBig (fixes
> GetFeature(long), DeleteFeature(long), etc...) (#6464)
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160418/fb59ba0d/attachment.html>
