[gdal-dev] Problem with gdal_pansharpen tool
Even Rouault even.rouault at spatialys.com
Fri Apr 22 08:54:04 PDT 2016
Le vendredi 22 avril 2016 17:37:19, Lorenzo Bernardi a écrit :
> Hi,
> i'm trying to perfom a pansharpening process using the gdal_pansharpen
> tool. I used the following code:
> #!/usr/bin/env python
> # -*- coding: utf-8 -*-
> import sys, os
> from osgeo import gdal
> def Usage():
>     print('Usage: gdal_pansharpen [--help-general] pan_dataset
> {spectral_dataset[,band=num]}+ out_dataset')
>     print('                       [-of format] [-b band]* [-w weight]*')
>     print('                       [-r
> {nearest,bilinear,cubic,cubicspline,lanczos,average}]')
>     print('                       [-threads {ALL_CPUS|number}]
> [-bitdepth val] [-nodata val]')
>     print('                       [-spat_adjust
> {union,intersection,none,nonewithoutwarning}]')
>     print('                       [-verbose_vrt] [-co NAME=VALUE]* [-q]')
>     print('')
>     print('Create a dataset resulting from a pansharpening operation.')
>     return -1
> def gdal_pansharpen(argv):
>     argv = gdal.GeneralCmdLineProcessor( argv )
>     if argv is None:
>         return -1
>     pan_name = None
>     last_name = None
>     spectral_ds = []
>     spectral_bands = []
>     out_name = None
>     bands = []
>     weights = []
>     format = 'VRT'
>     creation_options = []
>     callback = gdal.TermProgress
>     resampling = None
>     spat_adjust = None
>     verbose_vrt = False
>     num_threads = None
>     bitdepth = None
>     nodata = None
>     i = 1
>     argc = len(argv)
>     while i < argc:
>         if argv[i] == '-of' and i < len(argv)-1:
>             format = argv[i+1]
>             print("format " + format)
>             i = i + 1
>         elif argv[i] == '-r' and i < len(argv)-1:
>             resampling = argv[i+1]
>             print("resampling " + resampling)
>             i = i + 1
>         elif argv[i] == '-spat_adjust' and i < len(argv)-1:
>             spat_adjust = argv[i+1]
>             i = i + 1
>         elif argv[i] == '-b' and i < len(argv)-1:
>             bands.append(int(argv[i+1]))
>             i = i + 1
>         elif argv[i] == '-w' and i < len(argv)-1:
>             weights.append(float(argv[i+1]))
>             i = i + 1
>         elif argv[i] == '-co' and i < len(argv)-1:
>             creation_options.append(argv[i+1])
>             i = i + 1
>         elif argv[i] == '-threads' and i < len(argv)-1:
>             num_threads = argv[i+1]
>             i = i + 1
>         elif argv[i] == '-bitdepth' and i < len(argv)-1:
>             bitdepth = argv[i+1]
>             i = i + 1
>         elif argv[i] == '-nodata' and i < len(argv)-1:
>             nodata = argv[i+1]
>             i = i + 1
>         elif argv[i] == '-q':
>             callback = None
>         elif argv[i] == '-verbose_vrt':
>             verbose_vrt = True
>         elif argv[i][0] == '-':
>             sys.stderr.write('Unrecognized option : %s\n' % argv[i])
>             return Usage()
>         elif pan_name is None:
>             pan_name = argv[i]
>             pan_ds = gdal.Open(pan_name)
>             if pan_ds is None:
>                 return 1
>         else:
>             if last_name is not None:
>                 pos = last_name.find(',band=')
>                 if pos > 0:
>                     spectral_name = last_name[0:pos]
>                     ds = gdal.Open(spectral_name)
>                     if ds is None:
>                         return 1
>                     band_num = int(last_name[pos+len(',band='):])
>                     band = ds.GetRasterBand(band_num)
>                     spectral_ds.append(ds)
>                     spectral_bands.append(band)
>                 else:
>                     if ds is None:
>                         return 1
>                     for j in range(ds.RasterCount):
>                         spectral_bands.append(ds.GetRasterBand(j+1))
>             last_name = argv[i]
>         i = i + 1
>     if pan_name is None or len(spectral_bands) == 0:
>         return Usage()
>     out_name = last_name
>     if len(bands) == 0:
>         bands = [ j+1 for j in range(len(spectral_bands)) ]
>     else:
>         for i in range(len(bands)):
>             if bands[i] < 0 or bands[i] > len(spectral_bands):
>                 print('Invalid band number in -b: %d' % bands[i])
>                 return 1
>     if len(weights) != 0 and len(weights) != len(spectral_bands):
>         print('There must be as many -w values specified as input
> spectral bands')
>         return 1
>     vrt_xml = """<VRTDataset subClass="VRTPansharpenedDataset">\n"""
>     if bands != [ j+1 for j in range(len(spectral_bands)) ]:
>             band = spectral_bands[bands[i]-1]
>             datatype = gdal.GetDataTypeName(band.DataType)
>             colorname =
> gdal.GetColorInterpretationName(band.GetColorInterpretation())
>             vrt_xml += """  <VRTRasterBand dataType="%s" band="%d"
> subClass="VRTPansharpenedRasterBand">
>       <ColorInterp>%s</ColorInterp>
>   </VRTRasterBand>\n""" % (datatype, i+1, colorname)
>     vrt_xml += """  <PansharpeningOptions>\n"""
>     if len(weights) != 0:
>         vrt_xml += """      <AlgorithmOptions>\n"""
>         vrt_xml += """        <Weights>"""
>         for i in range(len(weights)):
>             if i > 0: vrt_xml += ","
>             vrt_xml += "%.16g" % weights[i]
>         vrt_xml += "</Weights>\n"
>         vrt_xml += """      </AlgorithmOptions>\n"""
>     if resampling is not None:
>         vrt_xml += '      <Resampling>%s</Resampling>\n' % resampling
>     if num_threads is not None:
>         vrt_xml += '      <NumThreads>%s</NumThreads>\n' % num_threads
>     if bitdepth is not None:
>         vrt_xml += '      <BitDepth>%s</BitDepth>\n' % bitdepth
>     if nodata is not None:
>         vrt_xml += '      <NoData>%s</NoData>\n' % nodata
>     if spat_adjust is not None:
>         vrt_xml += '
> <SpatialExtentAdjustment>%s</SpatialExtentAdjustment>\n' % spat_adjust
>     pan_relative='0'
>     print("panname: "+pan_name)
>     print(str(os.path.isabs(pan_name)))
>     print(str(os.path.relpath(pan_name, os.path.dirname(out_name))))
>     if format.upper() == 'VRT':
>         if not os.path.isabs(pan_name):
>             pan_relative='1'
>             pan_name = os.path.relpath(pan_name, os.path.dirname(out_name))
>     vrt_xml += """    <PanchroBand>
>       <SourceFilename relativeToVRT="%s">%s</SourceFilename>
>       <SourceBand>1</SourceBand>
>     </PanchroBand>\n""" % (pan_relative, pan_name)
>     print(vrt_xml)
>     for i in range(len(spectral_bands)):
>         dstband = ''
>         for j in range(len(bands)):
>             if i + 1 == bands[j]:
>                 dstband = ' dstBand="%d"' % (j+1)
>                 break
>         ms_relative='0'
>         ms_name = spectral_ds[i].GetDescription()
>             if not os.path.isabs(ms_name):
>                 ms_relative='1'
>                 ms_name = os.path.relpath(ms_name,
>         vrt_xml += """    <SpectralBand%s>
>       <SourceBand>%d</SourceBand>
>     </SpectralBand>\n""" % (dstband, ms_relative, ms_name,
> spectral_bands[i].GetBand())
>     vrt_xml += """  </PansharpeningOptions>\n"""
>     vrt_xml += """</VRTDataset>\n"""
>         f = gdal.VSIFOpenL(out_name, 'wb')
>         if f is None:
>             print('Cannot create %s' % out_name)
>             return 1
>         gdal.VSIFWriteL(vrt_xml, 1, len(vrt_xml), f)
>         gdal.VSIFCloseL(f)
>         if verbose_vrt:
>             vrt_ds = gdal.Open(out_name, gdal.GA_Update)
>             vrt_ds.SetMetadata(vrt_ds.GetMetadata())
>         else:
>             vrt_ds = gdal.Open(out_name)
>         if vrt_ds is None:
>             return 1
>         return 0
>     vrt_ds = gdal.Open(vrt_xml)
>     out_ds = gdal.GetDriverByName(format).CreateCopy(out_name, vrt_ds,
> 0, creation_options, callback = callback)
>     if out_ds is None:
>         return 1
>     return 0
> def main():
>     return gdal_pansharpen(sys.argv)
> if __name__ == '__main__':
>     sys.exit(gdal_pansharpen(sys.argv))
> My input file is a 7 bands geotiff file and the band 8 of an Landsat8
> images.
> If i use the script as follow:
> gdal_pansharpen panchro.tif multispectral.tif pansharpend_output.tif
> it returns with this error:
> ERROR 1: Missing one of rasterXSize, rasterYSize or bands on VRTDataset.
I guess it is because your GDAL python bindings are linking against GDAL <
2.1.0 .
http://www.spatialys.com
