[gdal-dev] Problem with Shapefile and CRS 2056/21781
Even Rouault even.rouault at spatialys.com
Sun Apr 24 08:34:33 PDT 2016
Le dimanche 24 avril 2016 17:29:36, Stefan Keller a écrit :
> Given a Shapefile "swiss_admin_boundaries.shp" in EPSG:2056 (or 21781,
> to be downloaded for free at [1]) I have problems transforming it to
> any other SRS/CRS.
Could you post the .prj file ?
> When doing this:
> > ogr2ogr -f "GPKG" swiss_admin_boundaries1.gpkg swiss_admin_boundaries.shp
> > -t_srs EPSG:3857
> ... swiss_admin_boundaries2.gpkg have a shift of about 150m.
> But when I convert Shapefile first e.g. to GeoPackage, and transform then:
> > ogr2ogr -f "GPKG" tmp.gpkg swiss_admin_boundaries.shp
> > ogr2ogr -f "GPKG" swiss_admin_boundaries2.gpkg tmp.gpkg -t_srs EPSG:3857
> > del tmp.gpkg
> ... swiss_admin_boundaries2.gpkg is correct!
> What could be the reason?
> :Stefan
> [1] https://opendata.swiss/en/dataset/swissboundaries3d-gemeindegrenzen
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
