[gdal-dev] Motion: Promote 2.1.0RC3 for release
Even Rouault even.rouault at spatialys.com
Mon Apr 25 08:25:13 PDT 2016
Hi Sean,
> I see something that looks like a regression between the beta and rc3 in my
> Rasterio CI
>   https://travis-ci.org/mapbox/rasterio/jobs/125120910#L1429
> That test was passing with the beta release. Any chance of holding the
> release up for 60 minutes while I double check that I'm just not building
> 2.1.0 wrong on Travis?
Sure, take the needed time.
Is this test about catching GDAL debug messages ? There was a change in GDAL
logging just before beta1 related to that (and normally with little impact in
the default behaviour), so if that worked with beta1, no reason that doesn't
work anymore. I'm short of idea otherwise.
Even
http://www.spatialys.com
