[gdal-dev] Motion: Promote 2.1.0RC3 for release
Sean Gillies sean at mapbox.com
Mon Apr 25 09:25:09 PDT 2016
Ticket here: https://trac.osgeo.org/gdal/ticket/6487.
I haven't seen any other problems with 2.1.0rc3. Fantastic work, everyone!
Thanks,
On Mon, Apr 25, 2016 at 9:45 AM, Sean Gillies <sean at mapbox.com> wrote:
> On Mon, Apr 25, 2016 at 9:25 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Hi Sean,
>> > I see something that looks like a regression between the beta and rc3
>> in my
>> > Rasterio CI
>> >   https://travis-ci.org/mapbox/rasterio/jobs/125120910#L1429
>> > That test was passing with the beta release. Any chance of holding the
>> > release up for 60 minutes while I double check that I'm just not
>> building
>> > 2.1.0 wrong on Travis?
>> Sure, take the needed time.
>> Is this test about catching GDAL debug messages ? There was a change in
>> GDAL
>> logging just before beta1 related to that (and normally with little
>> impact in
>> the default behaviour), so if that worked with beta1, no reason that
>> doesn't
>> work anymore. I'm short of idea otherwise.
> Can you point me to the commit changing the logging?
> I might be confused about whether I'm comparing rc3 behavior to beta1 or
> an earlier snapshot. There's definitely a change since April 1's dev
> prerelease.
> Sean Gillies
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160425/a5d228c5/attachment.html>
