[gdal-dev] compile error on windows
Ryan Grout rgrout at continuum.io
Fri Apr 29 13:17:56 PDT 2016
Hello,
I'm attempting to build GDAL for windows using Visual Studio 2008.
I've included the output of the build failure below.
I don't see anything wrong with the linking command (hdf5 library is
there).  I've double checked the exported symbols of hdf5.lib and it
definitely exports the symbols that gdal complains it can't find.
I get this failure on Windows 10 with Visual Studio 2008 and gdal 2.0.0
through 2.1.0 RC4.  I suspect it might have something to do with HDF 1.8.16
(since the problem only manifested itself since updating HDF5).
Searching this mailing list, I couldn't find similar failures.  Any help
would be appreciated.
Thanks,
Ryan
The compile fails with the following output:
        cd ..
        if exist gdal.lib del gdal.lib
        lib /nologo /out:gdal.lib port\*.obj gcore\*.obj alg\*.obj
frmts\o\*.obj ogr\ogrsf_frmts\ogrsf_frmts.lib ogr\ogr.lib gnm\*.obj
gnm\gnm_frmts\o\*.obj   apps\commonutils.obj apps\gdalinfo_lib.obj
apps\gdal_translate_lib.obj apps\gdalwarp_lib.obj apps\ogr2ogr_lib.obj
apps\gdaldem_lib.obj apps\nearblack_lib.obj apps\gdal_grid_lib.obj
apps\gdal_rasterize_lib.obj apps\gdalbuildvrt_lib.obj
ogrsf_frmts.lib(ogrjmllayer.obj) : warning LNK4221: no public symbols
found; archive member will be inaccessible
ogr.lib(ograpispy.obj) : warning LNK4221: no public symbols found; archive
nitf_gcprpc.obj : warning LNK4221: no public symbols found; archive member
cpl_recode_iconv.obj : warning LNK4221: no public symbols found; archive
        link /nologo /dll /INCLUDE:OSRValidate
/INCLUDE:OPTGetProjectionMethods  /INCLUDE:OGR_G_GetPointCount
/INCLUDE:OGRRegisterAll /INCLUDE:GDALSimpleImageWarp
/INCLUDE:GDALReprojectImage  /INCLUDE:GDALComputeMedianCutPCT
/INCLUDE:GDALDitherRGB2PCT  /INCLUDE:OCTNewCoordinateTransformation
port\*.obj gcore\*.obj alg\*.obj frmts\o\*.obj
C:\Users\builder\Miniconda2\envs\_build\Library\lib\xerces-c_3.lib
C:\Users\builder\Miniconda2\envs\_build\Library\lib\hdf.lib
C:\Users\builder\Miniconda2\envs\_build\Library\lib\mfhdf.lib
C:\Users\builder\Miniconda2\envs\_build\Library\lib\xdr.lib
C:\Users\builder\Miniconda2\envs\_build\Library\lib\netcdf.lib
C:\Users\builder\Miniconda2\envs\_build\Library\lib\geos_c.lib
C:\Users\builder\Miniconda2\envs\_build\Library\lib\hdf5.lib
C:\Users\builder\Miniconda2\envs\_build\Library\lib\libkea.lib
odbc32.lib odbccp32.lib user32.lib                        ws2_32.lib
gcore\Version.res  /out:gdal201.dll /implib:gdal_i.lib
   Creating library gdal_i.lib and object gdal_i.exp
gh5_convenience.obj : error LNK2019: unresolved external symbol
H5T_NATIVE_DOUBLE_g referenced in function "bool __cdecl
GH5_FetchAttribute(int,char const *,double &,bool)" (?GH5_FetchAttribute@
@YA_NHPEBDAEAN_N at Z)
hdf5dataset.obj : error LNK2001: unresolved external symbol
H5T_NATIVE_DOUBLE_g
H5T_NATIVE_FLOAT_g referenced in function "bool __cdecl
H5T_NATIVE_FLOAT_g
hdf5imagedataset.obj : error LNK2001: unresolved external symbol
H5T_NATIVE_FLOAT_g
H5T_NATIVE_INT_g referenced in function "bool __cdecl
hdf5dataset.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT_g
H5T_NATIVE_ULLONG_g referenced in function "enum GDALDataType __cdecl
GH5_GetDataType(int)" (?GH5_GetDataType@@YA?AW4GDALDataType@@H at Z)
H5T_NATIVE_ULLONG_g
H5T_NATIVE_LLONG_g referenced in function "enum GDALDataType __cdecl
H5T_NATIVE_LLONG_g
H5T_NATIVE_ULONG_g referenced in function "enum GDALDataType __cdecl
H5T_NATIVE_ULONG_g
H5T_NATIVE_LONG_g referenced in function "enum GDALDataType __cdecl
H5T_NATIVE_LONG_g
H5T_NATIVE_UINT_g referenced in function "enum GDALDataType __cdecl
H5T_NATIVE_UINT_g
H5T_NATIVE_USHORT_g referenced in function "enum GDALDataType __cdecl
H5T_NATIVE_USHORT_g
H5T_NATIVE_SHORT_g referenced in function "enum GDALDataType __cdecl
H5T_NATIVE_SHORT_g
H5T_NATIVE_UCHAR_g referenced in function "enum GDALDataType __cdecl
H5T_NATIVE_UCHAR_g
H5T_NATIVE_SCHAR_g referenced in function "enum GDALDataType __cdecl
H5T_NATIVE_SCHAR_g
gdal201.dll : fatal error LNK1120: 12 unresolved externals
NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual Studio
9.0\VC\BIN\amd64\link.EXE"' : return code '0x460'
Stop.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160429/c07adc98/attachment.html>
