[gdal-dev] Question on GDAL using libjpegturbo
Tomaka, Jacek jacek.tomaka at hexagongeospatial.com
Wed Aug 3 09:16:27 PDT 2016
Not directly related to your question...
It would be quite useful to allow compilation of external libjpeg library with dual 8_12 jpeg...
But it is being explicitly disabled by build scripts and code. i.e. DUAL_MODE_8_12 is allowed only with internal libjpeg.
I  have a version of GDAL with libjpeg-ipp (which is obviously external)  in both 8 and 12 but it required some code/build script modifications and probably broke a few things.
Would you be interested in a patch?
Regards.
Jacek Tomaka
________________________________________
Od: gdal-dev [gdal-dev-bounces at lists.osgeo.org] w imieniu Lucian Plesea [LPlesea at esri.com]
Wysłano: 2 sierpnia 2016 03:38
Do: Even Rouault (even.rouault at spatialys.com)
DW: gdal dev (gdal-dev at lists.osgeo.org)
Temat: Re: [gdal-dev] Question on GDAL using libjpegturbo
How about 8 and 12 bit JPEG simultaneously, using libjpegturbo?
Thanks,
Lucian
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
