[gdal-dev] Release of a GDAL 2.0.x and 2.1.x Visual Studio 2010 Solution (static and dynamic lib)
M. LATTES mathieu.lattes at yahoo.fr
Thu Aug 4 03:02:36 PDT 2016
Hi Everybody,
for some Visual Studio 2010 projects I've made a few time ago, I needed to update the GDAL lib that I was using into those projects to the GDAL version 2.I could make it with the GDAL Visual Studio Makefile projects as described in the wiki, but I like to have the "full project" with all the sources.
As I was not able to find one online, and as I read that the GDAL team did'nt intented to provide one I decided to make it myself.
I'm releasing it publicly, so feel free to download it and use it if you think it could help you.
You can find the repositories here :
GDAL 2.0.3 : https://github.com/MattLatt/GDAL_2.0.x_VCGDAL 2.1.1 : https://github.com/MattLatt/GDAL_2.1.x_VC
There is both dynamic lib project (aka dll) and static lib project and each one is configured for both x64 and x86 platform. I've kept the gdal source package almost as downloaded in a separate folder (see the readme file for the two slight modification).You can find it in the folder "gdal-2.y.z" of each repository.
All the Visual Studio 2010 workspaces are in the "libgdal-2.y.z" folder of each repository
All the 3rd part drivers libraries linked to the VC10 workspaces are in the "3rdpart" folder.In the "master" branches the following drivers are provided (curl, ecw, expat, geos, proj.4 and sqlite).For some there is just binaries (dll and lib) and for some there is a Visual Studio workspace.
I started with the GDAL 2.0.2 and 2.1.0 version so there is also a branch with the previous GDAL version for each repositories, but they will not be updated with new drivers.
I'v also made test projects (2 linking GDAL dynamically and 2 statically) for testing purpose. 3 are GDAL Utilities app and the last one is a very simple GDAL Drivers capabilities dump.
I intend to update those repositories with the latest GDAL releases.
So I hope it'll be usefull for someone.
Mathieu Lattes
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160804/a2a51c86/attachment.html>
