[gdal-dev] Release of a GDAL 2.0.x and 2.1.x Visual Studio 2010 Solution (static and dynamic lib)
Ivan Lucena lucena_ivan at hotmail.com
Thu Aug 4 06:41:03 PDT 2016
Hi Mateusz,
I far as I know the project generated by makegdal_gen.bat does not work with newer version of VS.
It used to be the case that we can import the project to newer version of VS but I think that MS dropped the support for that feature.
Have one of you manage to load the generated .vcproj into VS > 2010? I would like to know how to do that!
Best regards,
Ivan
> On Aug 4, 2016, at 8:08 AM, Mateusz Loskot <mateusz at loskot.net> wrote:
>> On 4 August 2016 at 14:00, M. LATTES <mathieu.lattes at yahoo.fr> wrote:
>> Hi Mateusz,
>> yes I was aware, but it generate workspace with only the all "makefile.vc"
>> in the project properties (at least when I tested it).
>> I wanted to browse among the sources and headers files in the Visual Studio
>> "Solution Explorer" or in the "Class View" (when debugging for example).
>> I don't think that it is possible with the "makegdal_gent.bat" but maybe I'm
>> wrong ?
> AFAIR, it does create "Source Files" and "Header Files" groups
> with sources attached.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
