[gdal-dev] Feasibility of expanding VRT schema to allow users to specify X/Y dimension for HDF data?
Thu Aug 4 19:38:25 PDT 2016
Brian / Even,
Certainly it is desirable for the HDF (and perhaps other super
flexible formats like netcdf) to support an open option to select
alternative axes.  But the ability to transpose a dataset could also
be quite valuable in the VRT driver to "fix" any input transposed
dataset.
I'm also not entirely certain why one couldn't supply an appopriately
transposed geotransform to accomplish something similar.  This could
be done without any code changes in the existing VRT format.
Best regards,
Frank
On Thu, Aug 4, 2016 at 3:32 PM, Even Rouault <even.rouault at spatialys.com> wrote:
> On Thursday 04 August 2016 16:31:25 H. Joe Lee wrote:
>> Hi,
>>   My name is Joe Lee and I'm very interested in improving GDAL's
>> capability to access NASA HDF4/HDF5 data so that users can work with
>> HDF easily through GDAL. For example, my goal is to allow users to
>> translate any HDF data into GeoTIFF via gdal_translate.
>>   I've worked with diverse NASA HDF products and provided solution for
>> visualizing data correctly through Python/MATLAB/IDL/NCL [1] and I
>> know that many products, other than HDF-EOS, may not work well with
>> GDAL because HDF is flexible and NASA data producers do not
>> necessarily follow the conventions that GDAL uses.
>>   By default, GDAL HDF4/HDF5 driver uses the following convention for
>> unknown products.
>>     For HDF4 (frmts/hdf4/hdf4imagedataset.cpp):
>>     // Search for the starting "X" and "Y" in the names or take
>>     // the last two dimensions as X and Y sizes
>>     iXDim = nDimCount - 1;
>>     iYDim = nDimCount - 2;
>>   For HDF5 (frmts/hdf5/hdf5imagedataset.cpp):
>>     int     GetYIndex() const { return IsComplexCSKL1A() ? 0 : ndims - 2; }
>>     int     GetXIndex() const { return IsComplexCSKL1A() ? 1 : ndims - 1; }
>>  The above code works well as long as Unknown HDF product follows the
>> above convention. However, in reality, HDF data can have an arbitrary
>> order in terms of Band, X and Y dimension like this:
>>   dset4D[XDim=360][YDim=180][Band1=2][Band2=3]
>>   dimindex:    0                      1            2             3
>>   Since ndims=4, ndims-2 becomes 2 and ndims-1=3. In such case, GDAL
>> generates 360x180 bands of 2x3 images, instead of the desired 2x3
>> bands of 360x180 images.
>>   Thus, I'm wondering if GDAL can expand VRT schema so that VRT allows
>> users to specify the correct dimension index because specifying
>> dimension order for each different NASA product in [1]  is
>> impractical. For example, I'd like suggest a new tag like
>> "SourceDimension" like below:
>>   <VRTRasterBand dataType="UInt16" band="1">
>>   <SimpleSource>
>>     <SourceFilename
>> relativeToVRT="0">HDF4_SDS:UNKNOWN:"DATA_WITH_4D_DATASET.hdf":7</SourceFilen
>> ame> <SourceDimension RasterXDim="0" RasterYDim="1" />
>>     <SourceBand>1</SourceBand>
>>     <SourceProperties RasterXSize="360" RasterYSize="180"
>> DataType="UInt16" BlockXSize="360" BlockYSize="180" />
>>   </SimpleSource>
>> </VRTRasterBand>
>>   Once user specifies correct dimensions by editing VRT, it can be
>> used by GDAL HDF4/HDF5 drivers and the HDF drivers read the data
>> correctly for GDAL's image buffer.
>>   Do you think it's right and feasible approach to solve wrong X/Y
>> dimension order problem? Or do you have any other existing solution
>> that can mitigate this problem in GDAL? The GEE project team has
>> experimented the idea by creating another separate XML file [2] but I
>> think it's time to sync with GDAL development team and come up with
>> the most elegant solution. In my opinion, VRT looks best and I wish
>> GDAL development team can give me some feedback on this idea.
> Joe,
> I would rather suggest to add open options to the drivers and pass them with
> the exiting VRT OpenOptions element, rather than adding a new element in the
> VRT that would be specific of a few drivers
>  <SimpleSource>
>     <SourceFilename>
> relativeToVRT="0">HDF4_SDS:UNKNOWN:"DATA_WITH_4D_DATASET.hdf":7</SourceFilename>
>    <OpenOptions>
>       <OOI key="RASTERXDIM">0</OOI>
>       <OOI key="RASTERYDIM">1</OOI>
>    </OpenOptions>
>     <SourceProperties RasterXSize="360" RasterYSize="180" DataType="UInt16"
>   </SimpleSource>
> Which is equivalent to:
> gdalinfo HDF4_SDS:UNKNOWN:"DATA_WITH_4D_DATASET.hdf":7 -oo RASTERXDIM=0 -oo
> RASTERYDIM=0
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
and watch the world go round - Rush    | Geospatial Software Developer
