[gdal-dev] 4th band as ALPHA on warp
Fernando Ribeiro fernando.ribeiro at geo-solutions.it
Sat Aug 6 06:20:54 PDT 2016
Dear list,
Currently we are working with 4 band tifs, first 3 bands as normal RBG
and the 4th as IR. On performing a warp operation from and to a VRT,
GDAL seems considering the 4th band as alpha, resulting in full black
pixels if 4th band value =0.
Some attempts were made to solve this issue, so far without success:
- Using the warp creation options PHOTOMETRIC=RGB and ALPHA=NO
- Manually editing the source VRT and replace Alpha color interpretation
to Undefined
Does anyone have more suggestions?
Thank you
Regards,
Fernando Ribeiro
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Fernando Ribeiro
DevOps / Support Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:   +39 0584 1660272
mob:   +39 333 	8128928
http://www.geo-solutions.it
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160806/3ef72a3d/attachment.html>
