[gdal-dev] Tiling with overlap
Margherita Di Leo diregola at gmail.com
Tue Aug 9 00:08:19 PDT 2016
Thank you all for the suggestions!
Cheers,
madi
On Mon, Aug 8, 2016 at 9:01 PM, Blumentrath, Stefan <
Stefan.Blumentrath at nina.no> wrote:
> Hei Madi,
> Given that you are quite familiar with GRASS GIS here a GRASS / GDAL
> solution:
> 1.      Patch all tiles into one VRT with gdalbuildvrt
> 2.      Link the VRT and the individual tiles to GRASS (r.external)
> 3.      Loop over the tiles and adjust you region accordingly and apply
> what GRASS module you like.
> So something like this:
> gdalbuildvrt ...
> r.external input=vrt ...
> r.external input=tile ...
> for tile in $(g.list type=raster ...)
> do
> g.region -p raster=$tile n=n+x s=s-x w=w-x e=e+x (where x is your desired
> overlap in map units)
> r.*
> done
> Cheers
> Stefan
> *From:* gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] *On Behalf Of *Margherita
> Di Leo
> *Sent:* 8. august 2016 15:43
> *To:* Ari Jolma <ari.jolma at gmail.com>
> *Cc:* gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] Tiling with overlap
> Ari,
> On Mon, Aug 8, 2016 at 3:01 PM, Ari Jolma <ari.jolma at gmail.com> wrote:
> 08.08.2016, 15:19, Margherita Di Leo kirjoitti:
> Dear all,
> is there a simple way to create tiles with a certain overlap?
> Do you mean by "overlap" the geographic area the tiles should cover?
> gdal2tiles.py creates the tiles for the area the source dataset covers. So
> you can control the area through the source dataset.
> Thanks for your answer, sorry I'm not sure I understand the methodology
> you are proposing. Let me explain what I'm trying to do so that the problem
> is clearer. I have a dataset that is a global coverage, e.g. GMTED [1].
> That is a tiled dataset. However for my processing chain I need tiles that
> overlap on each other for a certain number of pixels. This means that the
> area at the border of each tile should be covered by the tile itself and by
> the adjacent one to certain extent.
> My method would be the following. I would create a virtual mosaic and then
> create the tiles with this rule.  From the manual of gdal2tiles.py it is
> not clear to me if i can obtain this result. What do you mean by "you can
> control the area through the source dataset"?
> Thank you
> [1] http://topotools.cr.usgs.gov/gmted_viewer/
> Margherita Di Leo
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160809/52b69ea2/attachment.html>
