[gdal-dev] GDAL raster processing library?
Rutger kassies at gmail.com
Tue Aug 9 04:30:16 PDT 2016
Great discussion about improving the raster processing. As opposed to the
ideas above, of incorporating new machinery into GDAL, it might also
interesting to consider changing the API (a bit) so GDAL integrates better
with existing tools.
Within the Python ecosystem for example, there have recently emerged some
great tools for serious data processing. A combination of Dask (inc
Dask.distributed) and Numba for example allow relative easy scaling to
multicore (including GPU) and to clusters.
Dask easily handles windowed functions as discussed above, but also much
more complicated relations between 'blocks' for example with linear algebra,
matrix multiplication etc.
Here is a small experiment i made a while back, to test if i could use GDAL
for the I/O to populate Dask arrays. It computes the slope, a windowed
function, from an elevation map:
http://nbviewer.jupyter.org/gist/RutgerK/a2ad8c074c78d000dd4a1e35cc229dee
You basically only need a Python '__getitem__' interface so a Dataset can be
indexed similar as a Numpy array, and some attributes like the shape of the
data. That's much easier to implement than handling and scheduling blocks
yourself.
The downside is of course that you rely on third partys, and you get a
different experience based on the programming language you use because the
availability of packages/modules will be different. My example uses Python
and therefore would be useless to users of other languages.
Btw, has anyone thought of using vectorized Numba functions as GDAL pixel
functions? I have no clue whether that would technically work or even make
sense. Perhaps it would be a lot easier, and faster, then using Python
derived functions.
Regards,
Rutger
View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-raster-processing-library-tp5275948p5280032.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
