[gdal-dev] Fwd: Re: No SONAME in libgdal.so when building with --without-libtool
Even Rouault even.rouault at spatialys.com
Tue Aug 9 05:43:56 PDT 2016
Forwarding to the list.
----------  Message transmis  ----------
Sujet : Re: [gdal-dev] No SONAME in libgdal.so when building with --without-
libtool
Date : mardi 09 août 2016, 14:38:00
De : Gareth Francis <gfrancis.dev at gmail.com>
À : Even Rouault <even.rouault at spatialys.com>
Not having a SONAME entry doesn't directly cause any problems, however
libraries linked to libgdal.so can end up having a DT_NEEDED entry
containing the library path '../../build/lib64/libgdal.so' instead of just
'libgdal.so.20'. This happens when linking with GNU ld using CMake's
default behaviour. Linking without rpaths/etc probably avoids the issue.
Any executable which doesn't directly link to libgdal.so will then try to
look for '../../build/lib64/libgdal.so', regardless of the LD_LIBRARY_PATH
contents.
The only special case I can think of is Android, where the SONAME should
just be 'libgdal.so' without any version numbers.
I'll have to double-check what our version of libtool generated, I probably
just made a mistake.
On 9 August 2016 at 13:10, Even Rouault <even.rouault at spatialys.com> wrote:
> Gareth,
> What sort of issue do you encounter with SONAME not being defined ?
> I've tested your patch and it doesn't generate the same soname as libtool.
> libtool generates libgdal.so.20 deduced from the LIBGDAL_CURRENT /
> LIBGDAL_REVISION / LIBGDAL_AGE variables.
> Digging into history, it seems to be a voluntary choice not to define by
> default the soname in non-libtool builds, but I'm not sure why :
> https://trac.osgeo.org/gdal/changeset/4855
> Even
> > Encountered on Centos 6, x86_64
> > configured with --without-libtool, resulting libgdal.so has no SONAME
> entry
> > The link command for libgdal.so uses the variable 'GDAL_SLIB_SONAME'
> which
> > isn't defined in GDALmake.opt.in
> > The attached patch fixes the issue, and I believe will generate the same
> > name as libtool.
> > Thanks
> > Gareth Francis
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Gareth Francis
www.gfrancisdev.co.uk
