[gdal-dev] Probably bug with HDF4-EOS driver
Even Rouault even.rouault at spatialys.com
Wed Aug 10 05:14:55 PDT 2016
Le mercredi 10 août 2016 11:13:49, vous avez écrit :
> Dear GDAL developers,
> I was trying to access MODIS L1 data available e.g. here:
> ftp://ladsweb.nascom.nasa.gov/allData/6/MYD02HKM/
> and since GDAL version (2.1.0) the values of Ground Control Points are
> completely wrong. GCPPixel and GCPLine are twice larger than should be
> and GCPX, GCPY are just insane.
> gdalinfo
> HDF4_EOS:EOS_SWATH:"MYD02HKM.A2016148.1050.006.2016149162607.hdf":MODIS_SWA
> TH_Type_L1B:EV_500_RefSB
> Driver: HDF4Image/HDF4 Dataset
> Files: MYD02HKM.A2016148.1050.006.2016149162607.hdf
> Size is 2708, 4060
> Coordinate System is `'
> GCP Projection =
> GEOGCS["WGS 84",
>      DATUM["WGS_1984",
>          SPHEROID["WGS 84",6378137,298.257223563,
>              AUTHORITY["EPSG","7030"]],
>          AUTHORITY["EPSG","6326"]],
>      PRIMEM["Greenwich",0,
>          AUTHORITY["EPSG","8901"]],
>      UNIT["degree",0.0174532925199433,
>          AUTHORITY["EPSG","9122"]],
>      AUTHORITY["EPSG","4326"]]
> GCP[  0]: Id=, Info=
>            (0.5,0.5) -> (170569270408.57,2706131931253.88,0)
> GCP[  1]: Id=, Info=
>            (246.5,0.5) -> (33576161415.8712,2701109252213.01,0)
> GCP[  2]: Id=, Info=
>            (492.5,0.5) -> (14008281153.2792,2628614901860.17,0)
> GCP[  3]: Id=, Info=
>            (738.5,0.5) -> (5961274399.40133,2544871428176.69,0)
> GCP[  4]: Id=, Info=
>            (984.5,0.5) -> (2034123015.4764,2457627807804.38,0)
> GCP[  5]: Id=, Info=
>            (1230.5,0.5) -> (855102595.575362,2365791424551.01,0)
> Earlier version (2.0.2) reports correct values
> gdalinfo
> HDF4_EOS:EOS_SWATH:"/home/antonk/py/nansat-lectures/notebooks/examples/nans
> at-paper/MYD02HKM.A2011229.1005.005.2011230152517.hdf":MODIS_SWATH_Type_L1B
> :EV_500_RefSB Driver: HDF4Image/HDF4 Dataset
> Files: none associated
> Size is 2708, 4060
> GCP Projection =
> GEOGCS["WGS 84",
>      DATUM["WGS_1984",
>          TOWGS84[0,0,0,0,0,0,0],
>          AUTHORITY["EPSG","9108"]],
> GCP[  0]: Id=, Info=
>            (0.5,0.5) -> (59.6357002258301,61.7213020324707,0)
> GCP[  1]: Id=, Info=
>            (246.5,0.5) -> (51.7233047485352,61.6709632873535,0)
> GCP[  2]: Id=, Info=
>            (492.5,0.5) -> (47.139404296875,61.4298629760742,0)
> I was installing GDAL using conda either the standard channel (e.g.:
> conda install gdal=2.1.0) or the conda-forge one (e.g. conda install
> gdal=2.0.2 -c conda-forge). The results are the same.
> Can you please confirm that this is reproducible without conda and I can
> submit a ticket?
Confirmed. Fixed per https://trac.osgeo.org/gdal/ticket/6618.
Even
http://www.spatialys.com
