[gdal-dev] OGR - S57 - geometry extraction issue
David Ferdoille david.ferdoille at gmail.com
Fri Aug 12 00:32:36 PDT 2016
Hello,
Thanks for the responses,
After a long afternoon of tests :
I try to access a WRECKS object, compose by an only point, with a QUAPOS
specific value of 5, and an POSACC of 500.0 (find it using CARIS Easy View)
1-
In ogrinfo -oo "RETURN_PRIMITIVES=ON" -oo "RETURN_LINKAGES=ON" -oo
"LNAM_REFS=ON" file.000 WRECKS, I found the object, but no QUAPOS or POSACC
(logical because the 2 attributes are not directly linked to the object,
but to the geometry).
2-
"LNAM_REFS=ON" file.000 IsolatedNode, I found the node representing the
object but also no QUAPOS or POSACC.
3-
"LNAM_REFS=ON" file.000 M_QUAL, I found an only object, spatially
containing my wreck object, but POSACC is null.
4-
"LNAM_REFS=ON" file.000 M_QUAL, I found 20 objects, but QUAPOS is null for
all of them.
5-
No M_ACCY table is present in my dataset.
According to me, the good way to get these attributes, is the second one
(2-), but even if I try a lot of things, I didn’t manage to :
-          Trying all the S57 option with –oo
-          Trying to change the CSV types and attributes catalog used by
GDAL
-          Etc…
Does someone know if it is possible to get these attribute through GDAL/OGR
If not, is there another way to get this attributes (python GDAL scripts ?
another command line software ?)
Thanks again for your help !
Regards
David
2016-07-29 11:31 GMT+02:00 teddy guerin <teddyguerin at yahoo.fr>:
> Hi,
> Up for my previous answer.
> I was wrong for lines and area values POSACC, QUAPOS are on edges and not
> on "real object".
> Regards
> Ted
> *De :* David Ferdoille <david.ferdoille at gmail.com>
> *À :* gdal-dev at lists.osgeo.org
> *Envoyé le :* Mercredi 27 juillet 2016 15h12
> *Objet :* [gdal-dev] OGR - S57 - geometry extraction issue
> Hello all,
> We are trying to render S57 files as ENC through Geoserver.
> We convert S57 to shapefiles thanks to ogr2ogr : 1 shapefile for 1 class
> (ex : COALNE) and 1 geometry type (LINE) :
> "LNAM_REFS=ON" CELLLL.000 COALNE
> ogr2ogr -skipfailures  -where "OGR_GEOMETRY='POINT' or
> OGR_GEOMETRY='MULTIPOINT'" SOUNDG_points.shp CELLLL.000 SOUNDG
> We use gdal-2.1.0 with the S57_CSV environnement variable
> (S57_CSV=/usr/local/share/gdal/ with s57*.csv files).
> We noticed that objects (of COALNE class for example) have multiple
> geometries and each sub-geometry have attributes like POSACC and QUAPOS
> which are important for S52 representation.
> We've succeeded to extract primitives (Edge, isolated points, connected
> points, ...), but it looks very complex to operate.
> We have some problems to extract geometries from s57 objects :
> - we noticed that, for an object, all sub-geometries are aggregated to one
> geometry
> - we didn't succeed to extract geometry attributes like POSACC and QUAPOS
> 1) Is there a way to not aggregate sub-geometries of an object and get
> this list of sub-geometries ?
> 2) Is there a way to extract geometry attributes like POSACC and QUAPOS ?
> 3) If not, are these features planned ?
> Thanks for your help !
> David
> gdal-dev mailing list
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160812/2db7c681/attachment.html>
