[gdal-dev] GDAL 2.1.0, released 2016/04/25
Francisco José Raga López franka1986 at gmail.com
Wed Aug 17 09:18:25 PDT 2016
mmm,,,don't work.
I'm dowload the gdal 2.1.0 installer from this site:
http://www.gisinternals.com/query.html?content=filelist&file=release-1800-gdal-2-1-0-mapserver-7-0-1.zip
and this is installed in C:\Program Files\GDAL
Then I have created the environment path:
GDAL_PATH:     C:\Program Files\GDAL
PATH:      %GDAL_PATH%
GDAL_DATA:    %GDAL_PATH%\gdal-data
GDAL_DRIVER_PATH: %GDAL_PATH%\gdalplugins
PROJ_LIB: %GDAL_PATH%\projlib
JAVA_HOME: C:\Program Files\Java\jdk1.7.0_80
ok?and then created a simple project where I add the gdal.jar in the
java build path and in this jar add "Native library location"
C:/Program Files/GDAL.
Run the example:
package testgdal;
import org.gdal.gdal.*;
public class test {
public static void main(String[] args) {
     gdal.AllRegister();
And report this error:
Native library load failed.
java.lang.UnsatisfiedLinkError: C:\Program
Files\GDAL\native\gdaljni.dll: Can't find dependent libraries
Exception in thread "main" java.lang.UnsatisfiedLinkError:
org.gdal.gdal.gdalJNI.AllRegister()V
at org.gdal.gdal.gdalJNI.AllRegister(Native Method)
at org.gdal.gdal.gdal.AllRegister(gdal.java:493)
at testgdal.test.main(test.java:5)
What I What am I missing?
thanks a lot
Analista/Desarrollador GIS Open Source "QGis"
Móvil: (+34) 654275432 | e-Mail: franka1986 at gmail.com | skype: francisco_raga
Github: https://github.com/All4Gis
Linkedin: https://es.linkedin.com/in/franciscojoseragalopez
"La vida real no tiene ningún mapa.."  Ivy Compton Burnett
2016-08-17 15:12 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> Le mercredi 17 août 2016 14:58:24, Francisco José Raga López a écrit :
>> HI.
>> I'm using gdal for java in a personal project,but I have a question.
>> What version java is need?
> 1.5 or later
>> I'm using eclipse and If I use jdk 1.7.0 return this error,when debugging.
>> java.lang.UnsatisfiedLinkError: C:\Program Files\GDAL\gdaljni.dll: No
>> se encontró el proceso especificado
>> But in jdk 1.8 it ok.
>> gdal 2.1.0 need java 1.8 or higher??
> No, it is likely an issue with the PATH and/or -Djava.library.path=... not
> pointing to gdaljni.dll and/or libgdal20.dll
>> thanks
>> francisco_raga Github: https://github.com/All4Gis
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Spatialys - Geospatial professional services
> http://www.spatialys.com
