[gdal-dev] Fwd: GDAL 2.1.0, released 2016/04/25
Francisco José Raga López franka1986 at gmail.com
Wed Aug 17 23:45:58 PDT 2016
Thanks for your quick response.
Ii I change the version to *GDAL 1.11.0*, released 2014/04/16,and use
*jdk1.7.0_80* any problem show in console,is in version *2.1.0 *only  the
issue.
*2.1.0* is compatible with java *jdk1.7.0_80*??
*2.1.0 *and *jdk1.8.0_91 *works,perfect.
thanks again
2016-08-18 0:36 GMT+02:00 Brad Hards <bradh at frogmouth.net>:
>> mmm,,,don't work.
> Not very descriptive....
>> GDAL_PATH:     C:\Program Files\GDAL
> Maybe you need to quote the path, or use something with no space?
> Brad
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160818/275786b2/attachment.html>
