[gdal-dev] GDAL 2.1.0 build error (32 bit, Mac)
Calogero Mauceri mauceri at actgate.com
Wed Aug 24 07:00:02 PDT 2016
Hi all,
I'm trying to build GDAL 2.1.0 in 32 bit on Mac OS X.
I set the following environment variables
export CFLAGS="-arch i386"
export CXXFLAGS="-arch i386"
export CPPFLAGS="-arch i386"
export LDFLAGS="-arch i386"
and then execute
./configure
The build stops with the following error
/bin/sh /Users/mauceri/work/dev/libs/gdal-2.1.1/libtool --mode=compile
--tag=CXX g++ -I/Users/mauceri/work/dev/libs/gdal-2.1.1/port
-I/Users/mauceri/work/dev/libs/gdal-2.1.1/gcore
-I/Users/mauceri/work/dev/libs/gdal-2.1.1/alg
-I/Users/mauceri/work/dev/libs/gdal-2.1.1/ogr
-I/Users/mauceri/work/dev/libs/gdal-2.1.1/ogr/ogrsf_frmts
-I/Users/mauceri/work/dev/libs/gdal-2.1.1/gnm
-I/Users/mauceri/work/dev/libs/gdal-2.1.1/apps -arch i386  -Wall -Wextra
-Winit-self -Wunused-parameter -Wformat -Werror=format-security
-Wno-format-nonliteral -Wshorten-64-to-32 -Wshadow -Werror=vla
-Wnull-dereference -Wunused-private-field -Wmissing-prototypes
-Wmissing-declarations -Wnon-virtual-dtor -Woverloaded-virtual
-fno-operator-names  -I..  -I../jpeg -DHAVE_LIBJPEG -I../jpeg/libjpeg
-DINTERNAL_LIBGEOTIFF -Ilibgeotiff -DINTERNAL_LIBTIFF -Ilibtiff
-DBIGTIFF_SUPPORT -DOGR_ENABLED -arch i386
-I/Users/mauceri/work/dev/libs/gdal-2.1.1/port  -DGDAL_COMPILATION -c -o
../o/geotiff.lo geotiff.cpp
libtool: compile:  g++ -I/Users/mauceri/work/dev/libs/gdal-2.1.1/port
geotiff.cpp  -fno-common -DPIC -o ../o/.libs/geotiff.o
geotiff.cpp:9771:21: error: no member named 'my_function' in
'CPLStaticAssert<false>'; did you mean 'CPLStaticAssert<true>::my_function'?
         if( bSwap ) CPL_SWAP64PTR(&nTmp);
/Users/mauceri/work/dev/libs/gdal-2.1.1/port/cpl_port.h:655:5: note:
expanded from macro 'CPL_SWAP64PTR'
     CPL_STATIC_ASSERT_IF_AVAILABLE(sizeof(*(x)) == 1 || sizeof(*(x)) ==
8); \
/Users/mauceri/work/dev/libs/gdal-2.1.1/port/cpl_port.h:605:43: note:
expanded from macro 'CPL_STATIC_ASSERT_IF_AVAILABLE'
#define CPL_STATIC_ASSERT_IF_AVAILABLE(x) CPL_STATIC_ASSERT(x)
/Users/mauceri/work/dev/libs/gdal-2.1.1/port/cpl_port.h:604:30: note:
expanded from macro 'CPL_STATIC_ASSERT'
#define CPL_STATIC_ASSERT(x) CPLStaticAssert<x>::my_function()
/Users/mauceri/work/dev/libs/gdal-2.1.1/port/cpl_port.h:599:17: note:
'CPLStaticAssert<true>::my_function' declared here
     static void my_function() {}
Do you have any idea on how to fix this?
It seems a problem related to 32 bit compilation, if I compile GDAL in
64 bit I do not get any error.
Thanks,
Calogero
Calogero Mauceri
Software Engineer
Applied Coherent Technology Corporation (ACT)
www.actgate.com
