[gdal-dev] Public XYM or XYZM datasets?
Jaak Laineste jaak at nutiteq.com
Tue Aug 30 06:27:42 PDT 2016
It looks like I get only one link with some selected layers. Which layers are worth to try?
Your selected spatial data sets from the Finnish Transport Agency are available at the following link:
https://extranet.liikennevirasto.fi/livi/inspire-downloads/41...zip
The download link is valid for 10 days. For further information,please contact us at
Jaak
> On 29 Aug 2016, at 08:15, Ari Jolma <ari.jolma at gmail.com> wrote:
> In the download email you should have K and R data set options (two URLs). Only R has measured geometries.
> Ari
> 29.08.2016, 01:43, Carl Godkin kirjoitti:
>> Thank you very much for the response.  (This isn't the first time I've found great example data from Finland, by the way.  When I was experimenting with Lidar data a few years ago I found that Finland's collection was enormous!)
>> However, I can't see what you mean by the "R" data.  I selected various "Map Layers" and downloaded a few random shapefiles and none had "Measured" geometry (according to ogrinfo).
>> Thanks for your help.  Sorry if this is a dumb question!
>> carl
>> On Sun, Aug 28, 2016 at 12:48 AM, Ari Jolma <ari.jolma at gmail.com <mailto:ari.jolma at gmail.com>> wrote:
>> The Finnish national road data was my motivation to add M to OGR.
>> You can download it from
>> https://extranet.liikennevirasto.fi/extranet/web/public/latauspalvelu <https://extranet.liikennevirasto.fi/extranet/web/public/latauspalvelu>The page is also in English (click EN on top left)
>> The "R" data is the one you want.
>> The meta data etc is probably in Finnish only so you may need to experiment. M values are used to encode point-like attribute data into the line strings.
>> Good luck,
>> Ari
>> 26.08.2016, 01:43, Carl Godkin kirjoitti:
>>> Hi,
>>> While I had read about XYM and XYZM on the mailing list a few months ago, I had no experience with those geometry types until today when I happened to stumble on
>>> http://www-static.bouldercolorado.gov/docs/opendata/OSMPTrails.zip <http://www-static.bouldercolorado.gov/docs/opendata/OSMPTrails.zip>
>>> which contains a shapefile of trails around Boulder, Colorado that has
>>>     Geometry: Measured Line String
>>> in GDAL 2.1's ogrinfo.
>>> I would like to find some other datasets with XYM (and/or XYZM) geometry for testing.
>>> I didn't see any associated with the RFC or tickets associated with it.
>>> Can anyone point me to any others?  Thanks very much,
>>> carl
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev <http://lists.osgeo.org/mailman/listinfo/gdal-dev>_______________________________________________ gdal-dev mailing list gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/gdal-dev <http://lists.osgeo.org/mailman/listinfo/gdal-dev>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160830/a13a27e3/attachment-0001.html>
