[gdal-dev] Release of a GDAL 2.0.x and 2.1.x Visual Studio 2010 Solution (static and dynamic lib)
Ivan Lucena lucena_ivan at hotmail.com
Tue Aug 30 12:21:09 PDT 2016
Hi Mateusz/Jeff,
Please try the new version of "makegdal_gen.bat".
It will generate projects ready to use in newer version of Visual Studio.
I tested it only in VC++ 12.0 (VS 2013).
Add comments, if you like, to: https://trac.osgeo.org/gdal/ticket/6635
Regards,
Ivan
Sent: Monday, August 15, 2016 3:37 PM
To: Mateusz Loskot; Jeff McKenna
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Release of a GDAL 2.0.x and 2.1.x Visual Studio 2010 Solution (static and dynamic lib)
Mateusz,
Thanks for the tip.
Yes, the project is loaded but it is not a "Makefile Project" anymore, so it's basically useless.
In previous VS versions once the .vsproj file was loaded and upgraded you could press F7 and "nmake -f makefile.vc" would start running inside the IDE.
That means you would have all the advantages of the IDE (debuggin/cross reference/refactoring/etc.) but still using the settings of nmake.local and running makefiles.
I am using VS 2013. Is that the same for you on VS 2015?
Thanks,
Ivan
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Mateusz Loskot <mateusz at loskot.net>
Sent: Thursday, August 4, 2016 5:44 PM
To: Jeff McKenna
On 4 August 2016 at 17:52, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
> On 2016-08-04 11:07 AM, Mateusz Loskot wrote:
>> 1. makegdal_gen 10.00 32 > makegdal10.vcproj
>> 2. Launch VS2015
>> 3. File > Open > Project/Solution...
>> 4. Select makegdal10.vcproj
>> 5. Accept to upgrade
> Can we make sure to document these steps, so they are not lost in emails?
> Somewhere on the BuildHints wiki would be great.  Possibly here?
> https://trac.osgeo.org/gdal/wiki/BuildingOnWindows
BuildingOnWindows - GDAL<https://trac.osgeo.org/gdal/wiki/BuildingOnWindows>
trac.osgeo.org
GDAL can be built on Win32 platforms using MS VC++ 6.x and MS Visual Studio .NET (C++). The source distribution includes NMAKE compatible makefiles for use from the ...
https://trac.osgeo.org/gdal/wiki/BuildingOnWindows#GeneratingVisualStudioproject
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160830/4e7fad1f/attachment.html>
