[gdal-dev] jpeg2000/jasper error compiling gdal 2.1 from git release branch
Donovan Cameron sault.don at gmail.com
Wed Dec 7 10:43:24 PST 2016
Awesome, patch works as expected and gdal builds against the latest jasper.
Thanks a lot.
diff --git a/frmts/jpeg2000/jpeg2000_vsil_io.cpp
b/frmts/jpeg2000/jpeg2000_vsil_io.cpp index 74f1e64..3a948d0 100644 ---
a/frmts/jpeg2000/jpeg2000_vsil_io.cpp +++
b/frmts/jpeg2000/jpeg2000_vsil_io.cpp @@ -209,7 +209,7 @@ static void
JPEG2000_VSIL_jas_stream_initbuf(jas_stream_t *stream, int bufmode, /*
The buffer must be large enough to accommodate maximum putback. */
assert(bufsize > JAS_STREAM_MAXPUTBACK); - stream->bufbase_ =
JAS_CAST(uchar *, buf); + stream->bufbase_ = JAS_CAST(unsigned char*,
buf); stream->bufsize_ = bufsize - JAS_STREAM_MAXPUTBACK; } } else {
On 07/12/16 11:22 AM, Even Rouault wrote:
> On mercredi 7 décembre 2016 11:19:11 CET Donovan Cameron wrote:
> > On 07/12/16 10:41 AM, Even Rouault wrote:
> > > You could as well replace the JAS_CAST(uchar *, buf); by
> > > JAS_CAST(unsigned char*, buf)
> > Thanks Even, that's helpful.
> > Whereabouts would I try to make this patch? Not sure what file to look
> > for to do this. Sorry!
> frmts/jpeg2000/jpeg2000_vsil_io.cpp, line 212
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Kind regards,
Donovan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161207/16dc2dcf/attachment.html>
